This is driving me crazy!
Old Sep 3, 2013 | 10:25 AM
Bunzil's Avatar
Bunzil
Originally Posted by jfoote2307
I definitely should have asked for a printout or something of the TSB, but I did get the labor taken off the bill.
Some guys in my local g/z club said it sounded like the rear axle. Anybody have thoughts on that?
I doubt it. If it comes and goes as a direct function of putting you foot on the brake then it's hardly the axle. BTW - doe it happen when you apply the emergency brake (carefully) at low speeds? That would definately point to something in the brakes.
Old Sep 3, 2013 | 12:18 PM
rmfnla's Avatar
rmfnla
Not necessarily. Using the brakes changes the dynamics of the wheels and can affect the axle.
Good suggestion re: the emergency brake...
Old Sep 4, 2013 | 01:10 PM
Bunzil's Avatar
Bunzil
I don't know what "the dynamics of the wheels means". That's a bit vague. The problem started after you had brake work done. Doesn't it make sense therefore that it's the brakes? Also, the noise in your video is a squeal brought about when you apply the brakes. Wheel bearings don't squeal, and they make noise continuously, and not when the brakes are applied.
Your problem is either shim related or you've got a piece of rust or grit lodged in there. Reassembling the lot and cleaning it should fix the problem and/or swapping the pads left/right sides.
Old Sep 4, 2013 | 06:48 PM
rmfnla's Avatar
rmfnla
Simply stated, the brake is attached to the wheel which is attached to the axle, so applying the brake changes the forces acting on the axle.
BTW, it's not my problem; I'm not the OP...
RichardMiami
Apr 24, 2019 02:19 PM
tt350z
Sep 22, 2015 12:05 PM
rgonz
Sep 11, 2015 04:07 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
mmnjtwa
Sep 7, 2015 02:27 PM
