Help with Big Brake Kit issue
Does anyone know if it's possible (or if available) for me to replace the rear 2-piston calipers for 4-piston calipers on my 2013 IPL G37? Several people have told me that the larger calipers will not fit the rear.....please help me out with this issue.....before I finally have to powder coat what I have and find out later that larger ones would have fit!!
Thanks,
Leon
Thanks,
Leon
Thanks,
Leon
Thanks,
Leon
No, they're not a direct fit. You'd need to fabricate mounting brackets and lines. They'll fit if you get appropriately sized wheels with the correct offsets. They are not plug and play.
Even if you are tracking the car, you do not need any larger brakes in the rear.
I purchased a G37 IPL converible (as stated above) and just had the Dealership install my big brake kit last weekend (AP Racing). Now, we're running into an issue with vibration at speeds between 60-70mph. Has anyone had similar issues with their upgraded brake system? The master techs, along with AP RACING techs, are completely stumped at this point on why this is happening. By the way,the vibration is more prominent when the top is down. Also, there is no vibration when I apply the brakes at that speed....even letting go of the steering wheel....the car stays straight. ****please help!! Any suggestions? *****
No...I just like the look of a big brake system and the fact that the red calipers match the interior. **just for looks, basically**
But if the wear-in period of 250miles doesn't fix the vibration issue, then I will definitely re-install the OE brakes and call it a day!
Ihtbealexxx
Aug 9, 2015 03:30 AM
