Brakes & Suspension Reviews on brakes & suspension for G vehicles.
Eibach sway bars review
Old Feb 20, 2013 | 08:05 PM
  #91
Well... I was going to just use the Eibach bushings and OEM brackets. I'm assuming these bushings from Eibach are polyethylene, like ES products. But I say that only because they're red and greased, which really could mean anything.
So, ES makes a frame bushing kit for our car? Do you have more info on that, please? Looking at EnergySuspensionParts.com, and seeing nothing except TR ends, and Whiteline Sways.
energysuspension.com | Sway Bar & End Link Bushings
I wasn't referring to subrfame bushings, but greasable sway bar bushings and brackets. Order the ones that correspond to the size of the Eibach sway bars.
Old Feb 20, 2013 | 08:11 PM
  #92
ashmostro's Avatar
ashmostro
The best solution are zerks, but the eibach poly bushings are ribbed (for his pleasure) on the inside and will hold a good amount of the really thick silicone stuff for a long time before needed relube. IMO its not that hard to unbolt the brackets and relube but its a personal preference thing.
Old Feb 20, 2013 | 08:35 PM
  #93
Dug around and identified the Eibach bushings as solid poly, like the ES. Didn't know about the ribs, but I see what you're talking about now... the inner-diameter of the bushing are threaded, not smooth. That's fascinating.
You know, I'm good to go with these bushings, OEM brackets, and a re-grease in a couple of years.
Thanks, guys.
Old Feb 20, 2013 | 08:38 PM
  #94
ashmostro's Avatar
ashmostro
I'm sure the bushings ARE es.... They supply for a lot of manufacturers.
Old Feb 21, 2013 | 08:40 AM
  #95
soundmike's Avatar
soundmike
lol@ash.
Thanks, guys.
I was surprised at the ribbing, too, as i went in thinking about running the dremel to it a few times to create pockets. I've used AMSOIL #2 synthetic grease and that stuff goes nowhere. Sometimes i wonder why i even bother adding more grease... other than to find an excuse to be in the garage and get under the car.
For added "hold" i also wrap the bar covered by the bushing with plumber's tape before packing with grease. I recently only added the tape to the front bar, but have had the rear bars with it + grease for a little over a year now without squeaking. Haven't changed or touched it since install.
Old Feb 21, 2013 | 08:52 AM
  #96
Of course you guys know that Ash sent me the Eibach bushings with the bars, and let me tell you, he was more than liberal with the grease. A little too generous, if you ask me. It's less like he coated the inner-diameter, and more like he dipped the damn things.
Kumbaya
Old Feb 21, 2013 | 09:00 AM
  #97
ashmostro's Avatar
ashmostro
What can I say, Rochester- my woman trained me well.
Old Feb 21, 2013 | 10:01 AM
  #98
Energy suspension prelube grease- you can find it easily on amazon
Here it is: Energy Suspension 9.11104 Formula 5 Prelube 8oz. Tub
Old Feb 21, 2013 | 11:02 AM
  #99
ashmostro's Avatar
ashmostro
Yep. Pretty sure that's what they come with from Eibach too. The little tube is what was in the package. Like I said, ES OEMs/subcontracts for a lot of other aftermarket manufacturers.
Old Feb 21, 2013 | 03:22 PM
  #100
GTLAW's Avatar
GTLAW
KW V1 with Eibach Sways, Front set to first hole rear set to middle! Best setup for the G!
Old Feb 28, 2013 | 04:34 PM
  #101
I'm happy enough using the local Infiniti Dealership for swapping tires winter & summer, so I thought I'd give them a shot, and inquiry about having them swap the sway bars while there next month. They're fine with the work, but were asking $220+ for the effort.
Um, what? And then I politely declined. LOL
Although Ash here would likely do it for the cost of a decent bottle of Cabernet, I have access to a trusted street/pro mechanic who would certainly have me in and out in under an hour.
Old Feb 28, 2013 | 09:56 PM
  #102
ashmostro's Avatar
ashmostro
I agree- that's highway robbery!!
And yes, I would definitely help you out for a bottle of wine, but I'm a cheap date...
Old Feb 28, 2013 | 10:32 PM
  #103
Rad_Slinger's Avatar
Rad_Slinger
Monro put on mine for $150.
pretty reasonable i would say. me no has lift, so was worth it.
Old Mar 1, 2013 | 03:29 AM
  #104
jb606's Avatar
jb606
Installing sway bars on the G is very easy provided you have a set of ramps and a basic set of hand tools. The hardest part was disconnecting the exhaust mid-pipes from the mufflers .
Old Mar 1, 2013 | 06:07 AM
  #105
ashmostro's Avatar
ashmostro
And on the sedan you don't even need to do that. As i mentioned earlier in this thread, all I needed to do was loosen two muffler clamps on only one side of the exhaust system to drop the pipes enough to get clearance. Didn't need to break any seals in the exhaust system itself. Remember that the sedan doen't use a single transverse muffler like the coupe does.
