Brakes & Suspension Reviews on brakes & suspension for G vehicles.
Eibach sway bars review
Old Mar 26, 2013 | 01:41 PM
  #136
ashmostro's Avatar
ashmostro
That actually sounds right, from memory...
Old Mar 26, 2013 | 01:43 PM
  #137
JSolo's Avatar
JSolo
Just say no!!!!!
Did mine about this time last year. Installed them on my back, so getting a torque wrench in there was challenging. So far nothing has loosened. My reference for the frame brackets was a bit tighter than an oil drain plug, and good and snug () for the end links.
Old Mar 26, 2013 | 01:48 PM
  #138
ashmostro's Avatar
ashmostro
Agreed - it's an easy install but Rochester doesn't want to mess up his manicure...
Old Mar 26, 2013 | 01:54 PM
  #139
Originally Posted by ashmostro
Sweet, so we can abuse you for 30 more days, got it!
Thanks, Ash.
Been reading a lot about aftermarket sways, and I'm going to also wrap the bars with yellow, gas-line teflon tape under the bushings.
Man, it's been a long, long winter.
Old Mar 26, 2013 | 01:59 PM
  #140
ashmostro's Avatar
ashmostro
Curious- why the tape? I feel like that will just cause more of a long term mess than not, after it inevitably shreds.
Is it for fear of squeaking? I'm tellin ya, with those ribbed bushings (giggle) and right the right grease (giggle^2) they were DEAD quiet for me, even in the dead of winter storms.
Old Mar 26, 2013 | 02:09 PM
  #141
I found overwhelming advice for the teflon tape, on countless car forums. And the common recommendation was for the gas-line yellow tape, which is thicker than the little white tape I'm familiar with. Personally, I'm good with the ribbed bushings and the ES pre-lube. And if my mechanic mocks me and says, "No, you're an idiot", well then I guess I won't use it.
He might just say that anyway, LOL. But it was only $2.
No squeaking for the entire three months you had the sways, huh? Three whole months...
Old Mar 26, 2013 | 02:17 PM
  #142
ashmostro's Avatar
ashmostro
If anything, adding something in there that thickens the interface could promote resistance. You want the motion to be as free of friction as possible so as not to contribute to the spring rate of the bar.
I'd stick with as-is unless you run into a problem. In which case I would point to a need for bushing replacement or better lube.
But that's just me...
Old Mar 26, 2013 | 02:22 PM
  #143
We'll see. I trust my guy's judgement. It wouldn't be the first time I ran something by him only to get pushed back. He's usually right, and sometimes he's saved me money at his own expense... hence the trust. Rarely get advice from him that I flat out disagree with. Either way, this is so-o minor, Ash.
Are you getting instant email notification or something? F5, F5, F5... LOL
Old Mar 26, 2013 | 02:28 PM
  #144
ashmostro's Avatar
ashmostro
Oh so minor indeed - you brought it up!
I'm faaaast
Old Mar 26, 2013 | 02:59 PM
  #145
soundmike's Avatar
soundmike
Even the white stuff works.
Old Mar 27, 2013 | 06:16 AM
  #146
ashmostro's Avatar
ashmostro
Touche' my friend. But three months on my car is probably twelve on most garage queens (absolutely not pointing at you, J- I'm saying in general I push my cars and their parts hard).
I'm intrigued by this teflon tape idea and will look into it. Probably won't do it, but will look into it for knowledge
Old Mar 27, 2013 | 07:35 AM
  #147
Miscellaneous knowledge is always a good thing.
And you had me at Touche'. LOL
Old Mar 27, 2013 | 08:37 AM
  #148
ashmostro's Avatar
ashmostro
Lol. Last week my colleagues decided my nickname is offically Ashole'. Accent intended.
Old Mar 27, 2013 | 09:10 AM
  #149
Zack342's Avatar
Zack342
rochester did you install these yet
Old Mar 27, 2013 | 09:21 AM
  #150
soundmike's Avatar
soundmike
I learned about it from track junkies. It's a neat trick and has worked well. You know i push my car almost as hard as you. Probably even harder, i'm not afraid of driving through curb-height flooding, either.
