Had the car pretty low then installed F&R SPC kit had alignment done now the car looks an once higher. Is this normal?! Now I have to lower it again...
Did you install it properly? You're supposed to load the suspension before you fully torque to bolts on the camber kits. It should have no affect on ride height. There are useful videos on youtube detailing the install steps made by SPC.
Wow ok thanks mike. The installer didn't want to hear any of my input. I will just reinstall it myself Thanks
Now isn't that a huge waste of time and money. You should b!tch at them for not doing it right the first time and tell them how to do it right. THIS is why I DIY...
PM me if you need some help.
Yea it was a waste and I think I am going to call on Monday. I always DIY I couldn't get the toe bolt out so that's the only reason I took it some where. I know I will be purchasing an air chisel this week. Bolt came out in 2 seconds.
If your camber kits were set to correct camber (made it more positive) than I would think this is expected to some degree.
The hardest thing is lining everything up but a little wiggle here and there, a pry bar perhaps to get things moving and the bolt will eventually go through. Getting it off was the easy part. PB Blaster, a hammer and a screwdriver (or pick) was all it took.
