Camber setting? Need help on this one guys!!!
Old Apr 19, 2012 | 04:42 PM
Jasperrr08's Avatar
Jasperrr08
Rear Camber setting? Need help on this one guys!!!
Whats the lowest rear camber setting can we dial on our G sedan without an aftermarket camber kit?
Old Apr 19, 2012 | 04:59 PM
GET_SOME's Avatar
GET_SOME
by lowest do you mean how far negative? if so it depends how low you are. if your stock hight i think it gives almost a degree of adjustment
Old Apr 19, 2012 | 05:16 PM
Jasperrr08's Avatar
Jasperrr08
yes lowest negative camber setting. im currently 1.6" drop.
Old Apr 19, 2012 | 06:51 PM
GET_SOME's Avatar
GET_SOME
i think about 2.5 or so with that drop
Old Apr 20, 2012 | 11:09 AM
rpm&my_G35's Avatar
rpm&my_G35
On a Journey, S or X?
My G37S sedan
1.2" lower rear and they dialed the toe to 0.11 and the camber to -1.9L and -1.7R
1.5" lower front and they dialed the toe to 0.05 and the camber to -1.4L and -1.9R
Old Apr 20, 2012 | 12:52 PM
apexi957's Avatar
apexi957
I know someone that dialed in -4.2 in the rear on stock camber arms. The purpose of the camber kit is to dial camber back to safe specs, so i'm sure it has a wide range of adjustability.
Old Apr 20, 2012 | 01:08 PM
rpm&my_G35's Avatar
rpm&my_G35
^ the problem with that is that we want the stock to be more adjustable positively not negatively. Being able to go -4.2 (stock) doesn't help when lowering. It might help if we added a lift kit
The positive rear camber adjustment on the stock suspension isn't very much and on the front it's almost nothing.
Old Apr 20, 2012 | 01:55 PM
GET_SOME's Avatar
GET_SOME
^^^^ the stock front has camber adjustment? are you sure????
Old Apr 20, 2012 | 02:24 PM
rpm&my_G35's Avatar
rpm&my_G35
^ should I remove the word 'almost' from the sentence. lol
Old May 4, 2012 | 11:28 PM
greekgod544's Avatar
greekgod544
Im the one apexi was talking about. Ive got -4.2 camber in the rear. its completely maxed out. Attached a picture
Attached Thumbnails Camber setting? Need help on this one guys!!!-camber.jpg
Old May 5, 2012 | 12:15 PM
Jeff Rabbit's Avatar
Jeff Rabbit
I just installed my swift springs on my AWD and had the alignment done. The toe is good but the Front camber is -2.0 left and -2.2 on the right. The back is -1.6 left and -1.8 on right.
How far off is this? Is the camber kit required for front and back?
GFTW
Nov 11, 2015 02:56 PM
Ipp391
Aug 28, 2015 09:27 AM
IPL G37
Aug 13, 2015 08:25 PM
