Where to get alignment on coilovers?
I would do some research before calling out one of the most helpful members on this forum because you posted in the wrong section. I also would take his advice if you actually desire a greater response to your question about getting a wheel alignment...
Regional sections are a better way to stay away from those pesky trolls bothering you as well. So it would solve all of the current issues and lend you less opportunity of being rude to someone trying to help.
If you aren't a moderator of some kind you really need to stop policing the forums or seeing how far you can stick your nose up there until you get mod. I have the mantra that if you can't help you should just move along.
On a side note if you look at the NE boards you'd see they were pretty much useless unless you're looking for a year old post about a meet that never happened.
Thanks for the advice though. You may now return to hijacking threads because someone made you feel bad
I actually got what I needed. But ganging up on me is cool.
And dont worry! I won't be trolling in your threads ever again!
