Camber kit questions
Old Sep 30, 2011 | 08:41 PM
I'm new to all this but I just ordered some B&G S2 springs w/ a 1.4" F & R drop (not confirmed by me yet). I'm assuming I'll need some rear camber help and I'm hoping these will be all I need.
New Rear Eibach 2-corner set Camber and Alignment Kit Coupe Sedan G35 2007 Car | eBay
This states it's a "2 corner kit" does this mean it's for 2 rear wheels or just 2 points on each side? So in other words, do I just need to order one of these or two kits? If I do need to order 2 of these kits then I guess this is a better deal if SPC is a decent alternative to Eibach that is
SPC Alignment Components - Cam Bolts INFINITI G35 BASE;JOURNEY;SPORT;X;X SPORT 2007 - 2008 3.5 72265
Thanks for any help, I'm SUCHHH a newb to this dropping stuff
Old Sep 30, 2011 | 09:44 PM
rks's Avatar
rks
your links are only for the toe bolts for the rear tires. I think the camber arms for SPC and Eibach are esentially the same but those are not pictured. In this pic are the rear arms and the toe bolts. I have some heavy duty rear arms.
Old Sep 30, 2011 | 09:46 PM
P Casey's Avatar
P Casey
what car do you have in the first place
Old Oct 1, 2011 | 12:09 AM
Sorrry, I should have been clearer, an 09 G37 Journey sedan.
Will just the toe bolts get the toe in spec? I don't mind a bit of neg camber.
And will I just need one of the Eibach kits I linked?
Old Oct 1, 2011 | 12:23 AM
rks's Avatar
rks
yes, just one kit since you have 1 bolt for each rear side. however you will have to dremel a little to use the bolt.
I didn't use my toe bolts since the alignnment shop was able to get the toe close to spec but my camber was off after my Eibachs and they were able to get it close to specs with my adjustable rear camber arms.
SBG37
May 5, 2022 10:35 AM
GFTW
Nov 11, 2015 02:56 PM
equifire
Aug 31, 2015 03:42 PM
Ipp391
Aug 28, 2015 09:27 AM
kyro840
Aug 9, 2015 01:38 PM
