I see people doing just springs, but how's handling after?
Old Aug 24, 2011 | 11:26 PM
jjasonSU's Avatar
jjasonSU
Stock dampers aren't built to the specifications of aftermarket springs. So there will be more bounce as the spring rates are higher
Old Aug 24, 2011 | 11:30 PM
rpm&my_G35's Avatar
rpm&my_G35
Isn't this partly why Eibach has designed/engineered a progressive coil spring in the Pro Kit.
Old Aug 24, 2011 | 11:47 PM
The Jewbag's Avatar
The Jewbag
Youre not getting springs for handling. Period.
Old Aug 25, 2011 | 09:38 AM
G37Sam's Avatar
G37Sam
Lowering springs are for looks, any addition to handling is just a minor plus
Old Aug 25, 2011 | 09:42 AM
P Casey's Avatar
P Casey
best way to go is to get coils, but you also can get good shocks, springs, struts and sways.
Old Aug 25, 2011 | 11:07 AM
TomPeters's Avatar
TomPeters
I have the Eibach Pro-kit springs with Tokico HP blue's and the handling is vastly improved over the stock S suspension. Sway bars help too.....
Old Aug 25, 2011 | 11:56 AM
kaoticdemize's Avatar
kaoticdemize
sway bars are a must imo
Old Aug 25, 2011 | 12:09 PM
Adam West's Avatar
Adam West
Typically springs are not going to improve your handling a great deal, especially when you're pairing them up with the OEM struts. More often than not, you will end up shorteneing the lifespan of the struts quickly and they will blow out/leak making your ride worse (and dangerous) than OEM was. I've seen this happen numerous times when folks pick a pretty high rate lowering spring and the struts blow in like 10k and their car is bouncing all over the road.
If anything with the lowering springs, you're probably better off going with a drop that isn't too aggressive (i.e. less spring rate) and it will probably save your struts.
Old Aug 25, 2011 | 12:21 PM
TomPeters's Avatar
TomPeters
^ correct.... my front left OEM strut went completely out after only ~4k miles and when I switched over to the Tokico's it was a night and day difference. Pro-kit with OEM struts was close to the stock ride with a little less body roll. Pro-kit with Tokico's (which are made for up to a 1.5" drop) compliment each other perfectly. I think this is a great drop if you would like to keep the cost under $500
Old Aug 25, 2011 | 03:31 PM
joselitopr's Avatar
joselitopr
I am looking at the website and I dont see the struts for a sedan? where did you get yours?
Ok i found it but they are for 2006 and below can i use those on a 09 sedan?
Old Aug 25, 2011 | 04:41 PM
TomPeters's Avatar
TomPeters
No, get the ones for the G37 coupe. Most of the suspension components are interchangeable between the newer G's & Z's and the weights are very close too so the dampening is just fine.
Junchao Sun
Oct 8, 2015 11:06 AM
ArmyBoyd
Sep 22, 2015 08:54 AM
G10
Sep 17, 2015 11:42 AM
chris_s
Sep 8, 2015 03:37 PM
pnk
Sep 7, 2015 04:31 PM
