Brakes Feel Hard After Spacer Install
Old Nov 3, 2009 | 10:34 AM
maxipad96's Avatar
maxipad96
Hello all. Thanks in advance for any response.
I recently put spacers on the rear of my car. Because I needed to put in longer wheel studs, I had to remove the caliper.
Unfortunately during the removing process, I didn't read the instructions and instead of unbolting the correct 2 bolts to remove just the caliper, I unbolted the 4 bolts that hold the caliper together. Yes, I am a dummy. So when I removed the caliper, it came apart. During the process, a nominal amount of brake fluid leaked out. I then put the caliper/pad back together and bolted it back on to the rotor.
Checked the next morning and no fluid was leaking etc. So I thought I was good. Now this morning on the way to work my brake pedal feels extremely hard and my VDC light popped up. Also, braking obviously isn't performing like it should. Before I bring it in does anyone have any idea what could be the issue. I'm going to check the fluid to make sure there is enough, but it didn't' seem like enough leaked out to be that big of a problem.
Thanks for the help.
-Steve
Old Nov 3, 2009 | 10:45 AM
GiGGaplease's Avatar
GiGGaplease
you should have bought the ones with built-in studs..makes life much easier.
Old Nov 3, 2009 | 10:54 AM
maxipad96's Avatar
maxipad96
I know it, but I only needed a 10 and a 5 and no companies make the bolt on's for such a low spacer.
Old Nov 3, 2009 | 11:17 AM
Kidcane's Avatar
Kidcane
Florida G Club
A) Easier does not = better. Stud replacement is the way to go.
If you lost brake fluid and your VDC light is on then your fluid is probably low and that will make the brakes feel different....I guess?
Old Nov 3, 2009 | 04:51 PM
maxipad96's Avatar
maxipad96
You guys think I should take it into the dealer and be like WTF my VDC light is stuck on and try to get them to warranty it?. At this point the spacers/studs are not on the car anymore.
I checked the fluid level and it is inbetween low and high... I little bit towards the low side but still in the normal range.
Old Nov 3, 2009 | 05:49 PM
HamstersG's Avatar
HamstersG
Put some fluid in it. If you lost any fluid, then did you bleed your brakes?
Old Nov 3, 2009 | 05:53 PM
STOOF's Avatar
STOOF
Bleed your breaks and make sure you have enough fluid.
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
Intake
Dec 25, 2015 09:38 PM
blazeplacid
Sep 17, 2015 10:50 AM
xpcgamer
Sep 5, 2015 09:28 AM
TheLocNar
Aug 16, 2015 07:14 PM
