right size spacers?
Old May 6, 2009 | 10:59 PM
notsoricer's Avatar
notsoricer
right size spacers?
what would be a good size wheel spacer after dropping the car on eibach pro kit? and brands would help.. p.s. this is for stock wheels. would i need extended studs? thanks in advance!
Old May 6, 2009 | 11:04 PM
G37Sam's Avatar
G37Sam
you wont need to replace your studs if you go for the bolt on hubcentric ones
IMO, the best spacing for stock wheels & tires with no rubbing & perfect flush is the 20mm ones
I have pix in my profile
Old May 6, 2009 | 11:06 PM
HamstersG's Avatar
HamstersG
20mm if stay with OEM wheels and tire sizes. If you go with 245/275 tires on OEM wheels, then 15mm.
Old May 6, 2009 | 11:11 PM
notsoricer's Avatar
notsoricer
is it ok to put the 245/275's on if its a lease? most likely those would be my last set of tires due to my winter rims 1/4 the year.
Old May 6, 2009 | 11:14 PM
notsoricer's Avatar
notsoricer
sam, do u have rubbing with ur larger tires and the 20mm?
G37Sam's Avatar
G37Sam
275's & 20mm spacers will rub
Old May 6, 2009 | 11:17 PM
notsoricer's Avatar
notsoricer
what fits the wheel well gap better.. 15mm spacers and larger tires, or 20mm spacers and stock tires?
Old May 6, 2009 | 11:26 PM
HamstersG's Avatar
HamstersG
They will be close. The 245/275 + 15mm will be less stretched of a tire on the rim with more of a square sidewall look. So really both are good, but just depends on what you like.
Old May 7, 2009 | 09:14 AM
Kidcane's Avatar
Kidcane
Florida G Club
Just do 15mm and you wont have any issues at all. We are talking a difference of 5MM so visably there is not much difference but you will have zero rubbing issues. You will have to either do bolt ons or stud replacement. Personally I would only do stud replacement for safety reasons.
nbast
Sep 14, 2015 12:39 PM
si_driver
Sep 13, 2015 12:04 PM
JPat94
Sep 13, 2015 10:35 AM
ZSpeedPerformance
Supporting Vendors
Sep 4, 2015 11:09 AM
