How to adjust KW Variant Coilovers
Old Mar 13, 2009 | 06:37 AM
alunserjr's Avatar
alunserjr
I'm considering the KW coilovers. Once they are on the car, how do you adjust compression and rebound? Any manuall screen shots? I can't seem to find this info.
Old Mar 13, 2009 | 08:24 AM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Theres a **** you jsut turn. I plan to mess with mine next week.... i ll try to snap a pic.
Old Mar 13, 2009 | 03:38 PM
jnguyen's Avatar
jnguyen
how do you make sure all the **** are turn the same so there all a even drop
Old Mar 13, 2009 | 06:12 PM
alunserjr's Avatar
alunserjr
I can understand how you would have access to the top of the front struts, but what about the rear ones?
Old Mar 13, 2009 | 06:24 PM
STOOF's Avatar
STOOF
the **** clicks, so you turn them the same # of clicks.
the rears, if theyre the same as my JICs, you have to unbolt the rears and adjust the ****.
Old Mar 13, 2009 | 07:48 PM
jnguyen's Avatar
jnguyen
damn thanks for the Info Stoof. now i know sucks you can adjust it then see what it look like with wheels on then take off again. too much work.
is the stiffness the same way stoof?
Old Mar 13, 2009 | 10:03 PM
alunserjr's Avatar
alunserjr
oh - and I'm wanting to know how to control compression and rebound after the install - not to lower. I'm assuming you will set them to the desired drop, install, then play with compression and rebound. I thought I read somewhere about someone putting the rear ***** in the trunk.
Stevolkz33
May 28, 2016 02:36 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
BurtoN86
Nov 3, 2015 04:40 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
