is it a diy job
Old May 23, 2008 | 01:25 PM
fmrlegend's Avatar
fmrlegend
is it a diy job
I took a look under the car and the rear springs doesn't look to hard to remove/install, but the front seem a bit more complex with the strut and all. Any body out there that did it themselve with a rental spring compresor at your local auto parts store.
Old May 23, 2008 | 01:38 PM
gmlee86's Avatar
gmlee86
True, the back takes about 2 minutes to pop out and put the new one in, but the fronts were a little time consuming. It's doable, since a friend of mine did the install for me with a rental spring compressor.
Old May 23, 2008 | 01:51 PM
Protein Shakes's Avatar
Protein Shakes
This might help if you decide to DIY.
This is from a G35. If you have access to power tools and a spring compressor, you should be able to do it.
http://g35driver.com/forums/showthre...hlight=SPRINGS
http://www.g35nyc.com/forums/showthread.php?t=470
My next investment mod are power tools
Old May 23, 2008 | 02:25 PM
IP37's Avatar
IP37
it's easy. easier than a g35 even i'd say
Old May 24, 2008 | 02:48 PM
How long did it take you and what special tools (other than a spring compressor) did you need? Run into any unexpected snags? Did you have access to a lift or air tools?
Old May 24, 2008 | 04:04 PM
IP37's Avatar
IP37
we did use air tools the first time. but the second time (when i switched to coilovers) we just used breaker bars
rear is pretty straight forward...
on the front, you don't have to unbolt the a-arm.. look at the bottom of the strut, there is a black bracket.. unbolt that and unbolt the top 3 bolts and i think that was it
and the springs really aren't under much pressure.. so when you're taking the springs off, don't worry about compressing them as fas as you can.. just put a little pressure on them with the spring compressors then use your impact wrench to take off the top nut
Old Jun 11, 2008 | 10:38 AM
fmrlegend's Avatar
fmrlegend
sorry, forgot to thanks for those who had inputs on this subject. Those pictures annd video was awsome. When I get the green light from the wifee, I'll be sure to let you guys know how it went. I'm predicting by the end of summer. I just gotta keep on naggin' her about until she gives in.
Then after that, then I'll start working on the wheels.
For those who doens't have a family, it's harder than you think to upgrade your ride if the wifee doesn't agree with it, so pleez understand. I'm sorta fortunate that she's a car person herself.
Old Jun 12, 2008 | 12:51 AM
Dieseldoug22's Avatar
Dieseldoug22
I tried it with a spring compressor and it was a PITA for me. WELLLLL worth the $20 and 15 minutes taking it to a tire shop and having them do it.
Old Oct 6, 2008 | 09:42 AM
fmrlegend's Avatar
fmrlegend
ok,,, i had to take two tries and still couldn't get the front strut assemble off.
1st; ironically my car was too low to insert my hydrolic jack under the car so i had to use the stock jack to raised it a few inches. Took the wheel off, had to use a bit of muscles just to take off tthe 11mm nut that holds what ever line it is. think to myself, how the hell am i going to take that 19mm nut off of the bottom of the strut. with two feet planted in the wheel well, strain my muscles, damn thing didn't even budge. so i gave up.
brought my car to the shop; after sitting the for four hours and nothig was done with it. i got frustrated and took it back home. waste of my freakig time.
2nd; after talking to a friend, i went out to purchase a breaker bar. put that on that 19mm nut, w/o holding the other end that is connected to the sway bar, the bolt just turned with the nut. so i gave up again. damn.
any suggestions
Old Oct 9, 2008 | 04:54 PM
fmrlegend's Avatar
fmrlegend
alright, take 3.
when removing the front strut assembly, do i need to hold the bolt head when removing the nut at the bottom of the front strut assembly? the problem is that it is connected to the antisway bar, so i would need a skinny wrench to do so.
Old Oct 9, 2008 | 05:00 PM
finagle69's Avatar
finagle69
yeah, you'll likely need a small crescent wrench. Once the bolt is broken loose, you should be able to hand loosen it the rest of the way. when you really need the extra wrench is when you tighten everything back up.
Old Oct 11, 2008 | 03:58 PM
fmrlegend's Avatar
fmrlegend
Finally got my Tanabe springs installed. I ended up bringing it to shop in Temecula, CA for $200 labor. Pretty good deal. I still can't believe I got the springs on. I love that lowered look. Thanks to all those try to help me out.
timc00k
Feb 15, 2017 09:15 AM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
Awgd8
Sep 30, 2015 06:22 PM
Nsodano
Sep 28, 2015 02:53 PM
Allboutcali
Sep 26, 2015 03:43 PM
