Replacement Drilled Rotors Available
Old May 21, 2008 | 11:28 AM
  #31
Dieseldoug22's Avatar
Dieseldoug22
Not really. They are the stock rotors, no special metal or dipping process, and I haven't had the car in a situation were it would make the brakes fade.
Old May 21, 2008 | 11:39 AM
  #32
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Id say it would just make the brakes more effiecent... ie. cooling a bit faster...
Old May 24, 2008 | 01:34 PM
  #33
ChOy BoY's Avatar
ChOy BoY
those look real good!..any vendors out there offering new rotors anytime soon =)
Old Jun 25, 2008 | 10:40 PM
  #34
sumo8me's Avatar
sumo8me
Are rotors an easy DIY mod?
Old Jun 26, 2008 | 12:09 AM
  #35
Dieseldoug22
Wink
Yes. Take off the wheels.
Remove two bolts that hold on the brake calipers.
Move calipers.
Slide off old rotors.
Slide on new ones.
Install calipers.
Install wheels.
Pop top on beer.
Sip beer and marvel at your new rotors.
Old Jun 26, 2008 | 12:14 AM
  #36
nestle_!9's Avatar
nestle_!9
Move calipers.
Slide on new ones.
Install calipers.
Install wheels.
Pop top on beer.
sir which bolts are this? my rotors will be here this week
Old Jun 26, 2008 | 12:19 AM
  #37
Dieseldoug22
There are the two bolts that hold the caliper to the spindle. You can access them from the back side of the calipers. You need to slide the caliper off the rotor in order for the rotor to come off.
Old Jun 26, 2008 | 12:34 AM
  #38
nestle_!9's Avatar
nestle_!9
hmm so i will just slide the rotor out of the caliper correct? ,, hmm pretty easy then ---- i hope for me atleast
Old Jun 26, 2008 | 12:46 AM
  #39
Dieseldoug22
Actually you slide the caliper off of its bracket and the rotor, so now the caliper is hangin' free, and then pull the rotors off. But DO NOT let the caliper hang on the brake line.
Old Jun 26, 2008 | 07:13 AM
  #40
sumo8me's Avatar
sumo8me
Move calipers.
Slide on new ones.
Install calipers.
Install wheels.
Pop top on beer.
haha, now thats my kind of mod
Old Sep 29, 2008 | 08:06 PM
  #41
RedG37SNC's Avatar
RedG37SNC
Andy apparenlty has raised his prices.. it's now $795 for a set. Here's what they look like out of the box. You have to grind off the excess Zink with a few miles wear.
Old Oct 7, 2008 | 04:34 AM
  #42
myk1013's Avatar
myk1013
^ Nice!!
Old Oct 9, 2008 | 12:58 AM
  #43
silent06's Avatar
silent06
Are these OEM Akebono rotors that have been machine slotted, dimpled and then zinc coated? What is the quality of these rotors?
Old Oct 9, 2008 | 09:36 AM
  #44
RedG37SNC's Avatar
RedG37SNC
According to Andy, they order them from a local Infiniti dealer so they are OEM spec.
Old Oct 9, 2008 | 10:18 AM
  #45
The black zinc coated ones look sexy. Can you post pics of them after a couple of weeks being on the car? I'd like to see how they look with the wheels on after the coating is worn off the friction surface.
Also do you have to send in your stock rotors as a core exchange or is this a straight purchase?
