Replacement Drilled Rotors Available
Old May 11, 2008 | 08:29 PM
stuntman's Avatar
stuntman
IF you're going for bling, then ok.
If you track your car: Just get blanks. You could probably get away with slotted or dimpled, but cross-drilled is not recommended for track use.
0.02
Old May 11, 2008 | 09:37 PM
myk1013's Avatar
myk1013
Pls post pics when you get them. Should look nice!
Old May 11, 2008 | 09:51 PM
Dieseldoug22's Avatar
Dieseldoug22
Originally Posted by sumo8me
I cant seem to find the rotors for the g37. the ones for a g35 coupe seem to only be 400 for front and rear. Did you just buy the ones for the g35?
They are not for the G35. You just have to call up the place and order for them. I think I was the first one to ask for them for the G37. Andy called me back and said yes they can do it. If you do call, ask for Andy.
Originally Posted by Kidcane
So where your OEM discs wearing out or did you just decide to change them anyway?
No the OEM rotors are fine. I just have big spaces between the spokes of the wheels and want to have nice looking rotors. Since they are very easy to see. lol
Old May 15, 2008 | 12:19 PM
UNV-IT46's Avatar
UNV-IT46
when are you mounting these?
Old May 17, 2008 | 10:54 PM
Dieseldoug22
Pics of Rotors
Here are some pics of my new Dimpled/Slotted rotors.
Front
Rear
Easy to install. Just take off the wheels take off the calipers. Swap rotors and put it all back together.
Old May 17, 2008 | 11:14 PM
bboysteele's Avatar
bboysteele
Looks good!!!
Old May 17, 2008 | 11:32 PM
nestle_!9's Avatar
nestle_!9
wow! they look good indeed ,, how much did it cause you diesel doug?
Old May 18, 2008 | 12:45 AM
Dieseldoug22
They were about $630. For all 4 rotors. $320 for the front and $310 for the rears. It would have been cheaper if I went with the drilled instead of dimpled. I think the drilled were $550.
Old May 18, 2008 | 03:26 AM
B L U E S L A T E's Avatar
B L U E S L A T E
Looks like one piece... correct?
Old May 18, 2008 | 03:56 AM
Dieseldoug22
Yes one piece.
Old May 19, 2008 | 12:27 AM
nestle_!9's Avatar
nestle_!9
why is drilled more cheaper than the dimpled ones?
Old May 19, 2008 | 12:45 AM
wakeboardr116's Avatar
wakeboardr116
^^^ Yeah i was wondering that too.
Looks sick by the way.
Old May 21, 2008 | 03:49 AM
Dieseldoug22
I don't know exactly but I think because it is harder to line up the dimples on both sides, or because it costs more for an end mill bit than a drill bit... which can be sharpened. Or it costs WAY more for a milling machine than drill press. But I really don't know.
Old May 21, 2008 | 05:15 AM
  #29
Lou@Amplified's Avatar
Lou@Amplified
Front
Rear
SEXYYYYYYYYYYY
Old May 21, 2008 | 09:31 AM
  #30
Blackjack's Avatar
Blackjack
Looks awesome... Can you tell any difference?
