G37 and q50 steering wheel swap
Old Feb 2, 2020 | 07:44 PM
cotab's Avatar
cotab
Hey guys, I was curious to see as whether a q50 steering wheel would fit on a g37. I don’t care about the heated steering wheel, I just wanted the actual steering wheel, airbag, and controls. Any help would be great. Thanks!
Old Feb 3, 2020 | 09:16 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Well, the Q60 one fits my Coupe just fine. I don't see why Q50 one won't work on the Sedan. See post #1609:
Steering Wheel Swap- Coupe
Only issue is that the "BACK" button on the steering wheel is now the "SOURCE" button (I don't use it anyway). The heated steering wheels and the ones with the paddle shifter built into the wheel WILL NOT WORK. Make sure the switch connectors are the same BEFORE you buy the replacement- there are 2 types.
Old Feb 4, 2020 | 02:37 PM
PNW_IPL's Avatar
PNW_IPL
Air bag plugs up fine? Where'd you find the wheel and bag for 200??
Old Feb 4, 2020 | 04:22 PM
ILM-NC G37S
Fleabay.
Everything was plug-and play. Airbag module has the same two (yellow and orange) connectors for the dual-stage deployment. No SRS codes at all.
Old Feb 4, 2020 | 04:28 PM
PNW_IPL's Avatar
PNW_IPL
Fleabay.
cheapest I found was 600
Old Feb 4, 2020 | 04:35 PM
ILM-NC G37S
Right place, right time, super deal. Rare, but they do come along. I'm a cheap SOB, I'd never pay what some are asking... and the GTR wheels are even more ridiculously overpriced (but they should work as well).
Old Feb 8, 2020 | 08:52 AM
Surfnazi's Avatar
Surfnazi
I got mine for 200
Old Aug 4, 2022 | 11:56 PM
kyya's Avatar
kyya
Putting Custom Q50 Q60 Wheel in G37 Sedan
so If I say for instance I get a custom carbon q50 steering wheel would that work on a G37? Or would I be better off just getting the custom g37 OEM steering replacement, also somebody mentioned the paddles would rub and kinda be clunky
Old Aug 5, 2022 | 07:15 AM
ILM-NC G37S
If it fits the Q, it should fit the G. However, anything "custom" is hit-or-miss so buyer be informed and beware...
I am not aware of the paddles rubbing anything as they are fixed to the column. There may be some slight rubbing between the two shrouds as the new pieces get settled but the paddles (column or wheel mounted) have nothing to do with that. As for anything being "clunky..." ¯\_(ツ)_/¯
Old Aug 8, 2022 | 11:02 AM
kyya's Avatar
kyya
Q50 G37X sedan Steering Wheel And Paddle Shifter Swap
understood, do you know of anyone having a q50 G37 steering wheel swap? on this forum atleast
Old Aug 8, 2022 | 11:36 AM
ILM-NC G37S
From 2014-2017 the Q50 had a different style steering wheel (larger airbag pad). In 2018, the Q50 adopted the Q60 wheel (w/ smaller airbag pad). Just keep in mind that there are differences between the base and Red Sport wheels as far as the electronics go.
Here's are my swaps:
  • Q60 (base) to G37 (w/ original column paddles): thread;
  • Q60 (Red Sport) to G37 (w/ heat and wheel-mounted paddles): thread;
Another member here did a Maxima wheel swap: thread.
While not in the theme of a Q wheel, someone else did the eBay LED wheel swap: thread.
Plenty of options out there...
dbl07
Jun 20, 2018 06:18 PM
Blackedout11
Oct 5, 2017 01:23 AM
out0focus
Feb 17, 2014 11:01 AM
