Help Vibration on Center dash area
Old Sep 4, 2019 | 02:00 PM
minseuk84's Avatar
minseuk84
Hey Everyone im new to the form , 2010 G37x awd Sedan the reason im here is that... im getting a rattle vibration sound coming from the centre dash console its only there when im at the stop situation holding my brakes with D drive in place when i release the brakes its fine , i thought it was the blower motor but check it wasnt it im not sure elese to check if someone had similar situation please let me know thanks
Old Sep 19, 2019 | 09:19 PM
Gysper's Avatar
Gysper
I had something similar, but it was like a buzzing sound when braking around 20mph.
Old Sep 20, 2019 | 01:01 PM
Surfnazi's Avatar
Surfnazi
You sure it's not the windshield cowl it's a known issue, just takes some foam tape on backside like frolic factory. It wears from water and weather
Old Sep 20, 2019 | 01:11 PM
Gysper's Avatar
Gysper
Not sure about the OP, but for me it was the plastic piece above the steering wheel. I did try the windshield cowl fix but it ended up messing up my wiper arms, so now wind noise penetrates through the holes where the wiper arms are bolted down. So the plan is to take it into the dealer because you can actually see the bolt area rocking back and forth after the blades move.
By saying this, lots of combinations could be happening but it could’ve been negligence that when I tried fixing it, it broke something else. I made a post in the original thread so hopefully the dealer can fix it.
Old Sep 23, 2019 | 12:46 PM
Conboss's Avatar
Conboss
Check out the plastics around the windshield. I also recommend checking the windshield washer filler neck, as if the tab is missing from that sometimes it sounds like a vibration from the passenger footwell/windshield.
PDattaTV
Sep 8, 2019 03:50 AM
Gearratio
Jan 6, 2016 06:31 PM
2008G-Man
Apr 12, 2012 12:32 AM
shabbo
Apr 13, 2008 02:09 AM
