Vibration on idle!
Old Nov 27, 2016 | 11:54 PM
PDattaTV's Avatar
PDattaTV
Vibration on idle!
Hey guys! So recently i've noticed when i'm stopped and on drive, there is a distinguishable vibration coming from maybe the dash or somewhere. The vibration is loud enough that i can hear it pretty easily and noticeably. This didnt happen before and it only happens sometimes when coming to a halt.
Any solution? Thanks in advance!
Old Nov 28, 2016 | 07:25 PM
PDattaTV's Avatar
PDattaTV
bump
Old Sep 5, 2019 | 01:10 AM
minseuk84's Avatar
minseuk84
Hi
I know this is a old post but did you figure out the nosie im getting the exact same situation as you.
Old Sep 5, 2019 | 02:19 PM
Conboss's Avatar
Conboss
Washer fluid neck might be loose. Give that a check, if it's missing the clip form the top then swap one from the battery tray to that.
Old Sep 5, 2019 | 09:01 PM
Silver37's Avatar
Silver37
Ive actually had the same issue! Also, go over the entire engine bay and bang on the different plastic components to see if any of them are loose.
Old Sep 6, 2019 | 01:27 PM
teahead's Avatar
teahead
Find the temp coolant sensor and disconnect it and spray some electrical cleaner on it. Reconnect.
Old Sep 8, 2019 | 03:50 AM
minseuk84's Avatar
minseuk84
Found the problem the damn sound came from my battery compartment it was the bracket that holds it, this was on going for about 2 month now. 2 month ago i had to replace my battery and the new AGM battery was i little bit lower then the original one, the closer to the front bracket screws tight but the other side to the winshield was little loose cause it wont tigthen no more so i left it beacuse of the loose screw part it was rubbing on the firewall and the sound was traveling where the air vent is so i was hearing this sound inside my dash where the air vents are. So my solution was just getting rid of the bracket eliminate the problem yeh i thought it was the damn motor mount.
Jsbach1685
150
Feb 9, 2020 11:43 AM
paulreagan
14
Apr 21, 2019 08:45 PM
PDattaTV
Mar 28, 2018 09:50 AM
PDattaTV
Jul 21, 2017 09:54 AM
Jsmitty2002
General Tech Questions
Oct 8, 2015 06:47 PM
