Is there a bulb in the lighted door sill?
Old Sep 11, 2018 | 10:26 AM
Lance Mac's Avatar
Lance Mac
Hello, I have a 2013 G37x Sedan, the drivers side lighted door sill is no longer working....Will I need to purchase the entire door sill or does it have a bulb I can just buy? Thank you.
Lance
Old Sep 11, 2018 | 03:17 PM
slartibartfast's Avatar
slartibartfast
Welcome.
Left door bulb
The right door use the same bulb.
Old Sep 11, 2018 | 03:51 PM
Lance Mac's Avatar
Lance Mac
Thank you for the information, I was actually looking to see if there was a bulb for the door sill where it says Infiniti, if that's just an all in one unit or there is something I can change out for the light. Thank you again.
Old Sep 11, 2018 | 04:01 PM
ILM-NC G37S's Avatar
ILM-NC G37S
The illuminated door sills use LED's and typically are not replaceable. You might be able to replace them if you have soldering skills but more than likely the door sill will have to be replaced. A good parts guy should able to find out if you can buy just one sill rather than a whole new set. Occasionally there are used ones on eBay as well.
I would check the wiring first though.
Old Oct 11, 2019 | 12:23 AM
Joyryde's Avatar
Joyryde
Mine started flickering too. Does anyone know what sort of LED lamp is used? I might buy one and solder it in.
Old Oct 11, 2019 | 01:02 AM
codeflux's Avatar
codeflux
20 Year Member
It's probably not the LED - that's built inside the sill. It's more likely to be the wire that the sill connects with. I would begin with checking to see if it's intact.
Gus_Mahn
Oct 11, 2019 11:33 AM
137
Dec 21, 2015 05:57 PM
Jamsey Aimsey
Apr 17, 2015 07:30 PM
xxx4reggie
Jul 20, 2014 03:24 AM
TVPostSound
May 2, 2012 11:56 PM
