Help Aero side sill install Sport sill removal Q
Old May 2, 2012 | 06:52 PM
TVPostSound's Avatar
TVPostSound
When removing the Sport side sills with mudguards, can they stay together??
The instructions are not clear.
Old May 2, 2012 | 07:02 PM
BosMaSwaG37's Avatar
BosMaSwaG37
I will be uninstalling mine tomorrow and would like to know officially as well. From my understanding, they come off as one unit and the are 7/8 screw holding it in place.
Old May 2, 2012 | 07:37 PM
BosMaSwaG37
Go to www.infiniti-techinfo.com
Get PDF instructions on IPL side install
Old May 2, 2012 | 11:56 PM
TVPostSound
Did it!!
The IPL side sill instructions do not explain.
Front mud guards come off first. 2 screws behind wheel on inner fender lip, one machine bolt underneath, and one clip.
Then you proceed to take off the side sill per instructions.
All that is needed is a 1/4" drive 10mm deep socket, and ratchet.
Also an offset phillips screwdriver to remove the rear screw without removing the wheel.
The deep socket is needed because the rear deflector has nuts on long bolts attached to the body.
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
joeposter
Sep 8, 2015 04:36 PM
Upscale Speed
Aug 6, 2015 04:08 PM
