Driver side passenger window auto down on start
Hey all,
I recently bought a 2011 g37x sedan, which I love. However I am having an issue with one of the windows. When I start the car the rear driverside window opens all the way and I can't get it to go back up. I've tried the both buttons in the car to get it to go up, and to reset it. I have check both fobs for stuck buttons. The only thing I can do to make it go up is to lock the car using the manual key in the door and holding it into the lock position. I also discovered that using the window lock button prevents the window from opening.
Welcome to the site.
Don't know the answer but I suspect the switch on the motor is going bad. When one of my rear windows lost its auto-up function, the dealer replaced the entire motor.
The driver's door window switch assembly controls the power windows, it is an electronic device that uses CAN data to command the windows, and is possible to have data errors due to water damage. When these get water-logged, the power windows do wonky things. A common issue in 1st gen Titans when owners would let the window switches get rained on (easy to do in a Titan).
Probably, your car either had the door left open for a long time in the rain, or it may have been a flood car.
hope this helpshttps://www.myg37.com/forums/audio-v...dow-works.html
tune.rock.ug
G37 Convertible
Mar 13, 2017 02:35 PM
Jamsey Aimsey
Feb 10, 2017 08:05 PM
My2010G37x
Jan 20, 2017 09:27 AM
