6MT Shifter ratting issue
Old Feb 16, 2016 | 07:11 PM
JWise1203's Avatar
JWise1203
For the past couple of years my shifter has started sounding like a rattlesnake in cold weather (3800 rpms or above). This only happens when the car is in gear.
Anyone had this issue or know of a fix?
Old Feb 17, 2016 | 12:10 PM
SonicVQ's Avatar
SonicVQ
Interesting...
Try this: with engine off and the shifter in neutral, shake the shifter back and forth (side to side) firmly and quickly. Do you hear any rattles? There is a small screw inside the shifter that attaches the metal shifter "mohawk" to the shift ****, maybe it is loose?
Does the noise happen when engine load is light (1/4 throttle) and RPM above 3800?
Does it happen in all gears, including reverse?
Check the three small bolts that attach to the shifter mount:
Old Mar 26, 2018 | 10:32 PM
JWise1203's Avatar
JWise1203
As a follow-up in case anyone has this issue, my shift **** was replaced under warranty. All good now.
Old Mar 27, 2018 | 10:04 PM
saywat?'s Avatar
saywat?
the shift **** was rattling on its own? weird
JSolo
Group Buys
561
Apr 15, 2020 11:15 PM
IracknBack
May 8, 2018 09:52 AM
MilehighG37s
Sep 27, 2016 08:16 PM
