Trunk won't open
Old Mar 26, 2018 | 09:41 AM
KDS's Avatar
KDS
Trunk won't open
Hi there. I'm having an issue with my trunk. It won't open. I've tried using the button in the car as well as the button on the outside. The car beeps but the trunk won't release.
Any suggestions before I drive it to the dealership?
09 g37x coupe.
Thanks for the help.
Old Mar 26, 2018 | 12:25 PM
duriisimo's Avatar
duriisimo
Did you by chance switch it off? There is an on/off switch in the glove box
Old Mar 26, 2018 | 12:59 PM
KDS's Avatar
KDS
Thanks for the response. Yeah, I checked the switch in the glove box. Car doesn' beep at me when it' switched to lock. Wish it was that easy. I have some stuff in there I need today. Hopefully I can get in through the back seat.
Old Mar 26, 2018 | 01:37 PM
Bostonreefer's Avatar
Bostonreefer
good luck getting anything through that hole !! LOL
I would try to grab the emergency release threw that awfully small hole (must be for skis)
Old Mar 26, 2018 | 05:39 PM
KDS's Avatar
KDS
Hole was big enough I could crawl through and release the trunk. Got er open with pull cable but still won' open ith buttons inside or out.
Old Mar 26, 2018 | 10:21 PM
Epiphany's Avatar
Epiphany
Door open or closed when you try it? If open make sure the door's closed.
Old Mar 27, 2018 | 01:49 AM
KDS's Avatar
KDS
Same response regardless. 4 beeps. Thanks for the idea.
cheers
Old Mar 27, 2018 | 02:50 AM
JSolo's Avatar
JSolo
Just say no!!!!!
I attached a ziptie to the emergency release years ago when I got the car. I'm 6' tall and have relatively standard length arms for my height yet it's still nearly impossible to reach the pull through the slot. The ziptie makes it much easier.
https://www.myg37.com/forums/g37-sed...k-release.html
Old Mar 27, 2018 | 02:53 AM
KDS's Avatar
KDS
Hey there. My back seats fold right down. Climbed right through to open the trunk earlier today. Need to figure out what' going on with the buttons. Wondering if the key fob is the culprit.
Old Mar 27, 2018 | 03:05 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Sorry, missed the coupe part. Maybe fob battery issue?
Old Mar 27, 2018 | 02:28 PM
KDS's Avatar
KDS
Bought a new battery for the key fob. Didn' help. Thinking 5he lock actuator itself must be knackered.
Old May 22, 2018 | 01:30 PM
max0ut132's Avatar
max0ut132
I agree with KDS. After you check all the fuses, perform the test procedure in the service manual for the trunk latch release actuator.
Panamajon
G37 Convertible
Aug 24, 2024 09:05 PM
triassiic
Nov 25, 2014 12:55 AM
Chiino
Nov 21, 2013 03:31 PM
Mr. Nibiru
Oct 31, 2012 05:05 AM
basik
Intake and Exhaust
Sep 2, 2011 09:56 AM
