Front bumper and headlight damage
Old Feb 15, 2018 | 10:01 AM
Jamie69's Avatar
Jamie69
The headlight was only pulled from the socket basically ripped from it ... maybe they can rewire it ? And couldn’t the dent in the fender be banged out ? Also will a new bumper be fine ? The bumper was basically ripped out idk it looks repairable though
Some shops say they can fix my bumper/headlight/fender and some say I need a whole new one and a fender and headlight too . What do you guys think images are below
Old Feb 21, 2018 | 10:40 PM
JustROLLIN's Avatar
JustROLLIN
I am not a body expert, but based on what I see, I would agree that replacement parts are needed vs repair, except for the headlamp. Looks like the headlamp is not cracked or damaged, right? If that is the case, it should be repairable, which is nice cause its the most expensive part of those that you will need.
I am guessing shops that are telling you replacement versus repair are looking at their labor cost to actually fix the parts and it costing more than to just replace. Just a guess.
The front bumper cover is not terribly expensive, but I am not sure about the fender. The headlamp is $1000 plus from Infiniti, but a good used example can be found for significantly less. Sorry I cannot help more, just going off previous repairs on other cars and this car as well.
Old Feb 23, 2018 | 05:33 AM
Surfnazi's Avatar
Surfnazi
New bumper fender and light
Blend paint on hood and driver side door and reshoot new panels
Old Feb 24, 2018 | 10:56 PM
CømplexMuch's Avatar
CømplexMuch
You can likely fix the wiring yourself, have any pictures of where it came off? Check your local Craigslist for part outs, you’d be surprised how cheap you can find good condition parts. You may even get lucky and find the same color you need.
Old Feb 25, 2018 | 12:32 AM
stealthee's Avatar
stealthee
The fender is creased. Fixing it doesn't make financial sense. If it were just a dent then repair would be a likely option.
Bumper cover may be fixable but would need painted anyway. So you are back to labor cost vs replacement cost.
krnhyun
May 10, 2017 12:16 PM
pwcracer
Dec 19, 2016 04:35 PM
CarAddict
16
Aug 27, 2007 05:13 PM
minamshi
The M - Spot
Aug 9, 2007 09:47 AM
