Body Interior Exterior Lighting Reviews on body interior exterior lighting for G vehicles.
Review OEMassive Coupe headlights
Old Dec 10, 2017 | 02:23 AM
  #46
alberto555552's Avatar
alberto555552
Originally Posted by Arxylis
You won't need to remove the headlights, but it will be a tight area to work with. If you pull up the end of the weatherstripping above where the headlights are you'll see the adjustment screws:
I used a small ratchet with an extension and a U joint to get in there. It's either an 8mm or 10mm, I can't remember which.
Thank you very much, this was really helpful!!
Old Dec 10, 2017 | 07:49 AM
  #47
Victory's Avatar
Victory
Those do give a more modern look to the front end.
Old Dec 10, 2017 | 01:54 PM
  #48
Epiphany's Avatar
Epiphany
Assuming it's the same setup as OEM, the low beams can also be adjusted with a longer Phillips head screwdriver without removing anything. I want to say it's a #3 Phillips and 6"+ long.
Old Dec 19, 2017 | 04:23 PM
  #49
alberto555552
Has anyone figured out how to keep the led accent light on as a daytime running light and have it switchback to the turn signal when necessary. Is it even possible? Anybody have any ideas?
Old Jan 22, 2018 | 09:57 PM
  #50
Arxylis's Avatar
Arxylis
Average Joe
If you turn the parking lights on, then just the LED strip will illuminate and will switch to the orange turn signal when it is activated.
Old Jan 22, 2018 | 11:33 PM
  #51
alberto555552
I understand that, that's what I do when I want to turn them on, I just wish there was a way for it to just turn on with the car like a daytime running light, turning on the parking lights also dims the interior, and if you undim the interior it won't dim with the headlights turn on (first world problems I know) it's a constant switching of buttons and turning on and off things, I just wish they could be wired to turn on like daytime running lights and switch to turn signals when necessary
Old Feb 4, 2018 | 04:32 PM
  #52
Arxylis's Avatar
Arxylis
Average Joe
I'm sure they could be set up that way, just have to figure out which wires go to the LED strip and run power to them from a 12V switched source. You may need a relay of some sort to make sure that they operate correctly for the turn signals though.
Old Feb 9, 2018 | 05:30 PM
  #53
vofact's Avatar
vofact
Oem massive
yours aren't the smoked are they? I have a red coupe with the aftermarket black grill and Im thinking the smoked ones would look pretty nice???
Old Feb 9, 2018 | 10:17 PM
  #54
Arxylis's Avatar
Arxylis
Average Joe
Mine aren't smoked. Since they already have a black housing I didn't see much need for it. I also didn't want to compromise my light output any.
Old Mar 8, 2018 | 05:33 AM
  #55
Kaighal's Avatar
Kaighal
Question
Hello,
I have a question about these headlights.
There is another website that sells them (I do not know if I can mention its name ?), and on the description, they say :
2010 INFINITI G37
Fits Following Model(s):
Coupe with Factory HID/Xenon Headlights without AFS System
Will not fit Models with Factory Halogen Headlights.
My concern is about the AFS system, which my car has. I did not see anything about it on the OEMassive website, I tried to ask them, but never got a reply.
So... Does anyone know if it is a real restriction and if AFS-equipped G37's cannot use these headlights from OEMassive ? What would be your guess ?
Old Mar 8, 2018 | 05:49 PM
  #56
blov's Avatar
blov
Originally Posted by Kaighal
Hello,
Kaighal - check out the back half of this thread: https://www.myg37.com/forums/g37-cou...lashing-2.html
Looks like jaysont96 completed his install of the lights but now the afs dash light will not stop flashing - just something you might want to consider. These lights shine wide, even with variable adjustments. Sometimes I use the fogs to better illuminate the road but i kept the stock halogen yellow bulbs because I wanted to make sure there was a dust cover in place. So if your're used to the afs might want to pass on these.
I emailed OEM a couple times and received no reply either. You are not alone friend.
Old Mar 9, 2018 | 02:23 AM
  #57
Kaighal's Avatar
Kaighal
Oh, thank you for pointing me at the right direction, Blov !
Honestly, a permanent flashing light on the dash is not something I want to have in my car. And, yes, AFS is a sweet feature and you are right, I would probably miss it.
Thanks again
Old Mar 20, 2018 | 12:53 PM
  #58
Girlsare3vil's Avatar
Girlsare3vil
Question 1. Would these plug and play if you have AFS - the adaptive headlights? I know you will loss the functionality of this feature but would they still plug and play?
Question 2. If the high beam calls for an H7 bulb is the back able to be plug and play with a HID set up?
Question 3. I found them for $422.99 has anyone purchased these? The same?
Question 4. It looks as if there are lights underneath the low beams. I take this to only be a look and not actually any lights present?
Old Apr 27, 2018 | 03:22 PM
  #59
HarvirK's Avatar
HarvirK
Did any of you guys know where these headlights where made? Also my mechanic was telling me about aftermarket headlights leaking, do these leak too.
Old May 18, 2018 | 12:34 PM
  #60
Maneil Rana's Avatar
Maneil Rana
So after installing it looks like with AFS lights it the high beams simply won't always turn on, sometimes one light (either side) will not turn on, resulting flickering . 80% of the time it works, anyone else using an AFS car and have it working? The stock ballast has 3 connectors wheras this one only has one, likely causing issues. I have the AFS switch turned to off but maybe switching it to on may help, even if the car overrides it and alerts me to the off section.
For anyone asking these are made in the US, as I paid NAFTA duties not international duties when importing to Canada.
