power window fuse
Old Dec 2, 2019 | 10:21 PM
infiniti12coupw's Avatar
infiniti12coupw
Originally Posted by Roxehna
would that work on a g37 sport coupe infinity 2008?! One of my windows stoped working completly, stuck down. And my other window rolls down on its own everytime I open the door but I’m able to roll it back up. Could it be the fuse?
i would say go for it as well. It’s the least expensive and easiest option.
Old Feb 20, 2024 | 07:16 PM
wgriffith1956's Avatar
wgriffith1956
Red face Reseting the blue combo fuse fixted it
Just had the same experieience with my 2013 G37x Coupe. Passenger power window and lock had quit working. Removed the blue triple fuse block in the box next to the battery, blew out the area with a can of air. and reset the fuse block. All is working now. Thanks for the info.
Old Jun 4, 2025 | 08:08 PM
fgortalu's Avatar
fgortalu
possible fuse
had same thing happen. passenger window on 2011 g37 coupe stopped responding but door locks did. fiddle with the fuse and then the driver side stopped responding but passenger worked. i ended up buying a fuse on amazon which solved everything for 3weeks. then suddenly again! passenger window and now power lock not responding. maybe faulty fuse again? i do have to say these issues arose after i used a key to lock and unlock door. so not sure what the problem is now. but will get a replacement fuse again and try it out. i would think if its a master switch fuse replacement wouldn't help initially or cause a reverse window unresponsiveness. very weird
Old Jan 6, 2026 | 10:23 PM
JayDaFace's Avatar
JayDaFace
+1 on “ issues arose after i used a key to lock and unlock”
just happened to me. Driver Door works but neither passenger or rear windows go down. 2013 G 37 sport convertible
Old Jan 6, 2026 | 11:26 PM
fgortalu's Avatar
fgortalu
you can try to remove the fuse and put it back in after disconnecting battery. if that doesnt help buy a new fuse relay on amazon. mine started working after i took it out and reinstalled it(the new one i purchased). good luck
keithnellie
General Tech Questions
Apr 14, 2018 11:24 PM
JohnnysG
Apr 18, 2017 02:14 PM
SpeedBallDEVIL
Feb 17, 2017 11:36 AM
rottweiler
Mar 10, 2013 12:35 PM
