Front end conversion fog light wiring problem
Old Feb 6, 2017 | 11:07 PM
v36Kyle's Avatar
v36Kyle
Working on wiring the fog lights for my front end conversion. I've tapped into the factory wiring on both sides, but only the driver side works. I've tested the bulbs and ballasts on each side and they're all good. I also plugged in the old 07-09 headlight and the fog light works, so I'm stumped. The black and white wires are the ones I'm trying to tap.
Old May 8, 2017 | 12:42 PM
loganlhadley's Avatar
loganlhadley
Did you ever figure this out? I'm doing the front end conversion on my '07 G35 Sedan and will be tackling the fog lights in a couple of days.
Old May 9, 2020 | 11:00 AM
PNW_IPL's Avatar
PNW_IPL
Bump, anyone else know what wiring to tap to run wiring from factory harness to foglights? My 08 sedan has the fogs in the headlights, the 2010+ are down low in the bumper.
from the fsm this is all I could find on pinouts
Old May 9, 2020 | 11:32 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Is this what you are looking for? It is for the Coupe but I would imagine it is the same for the sedan as well:
I would imagine you could tap those two wires anywhere along the branch and run them to your bumper. For some strange reason the ground wire for the (L) fog runs from the IPDM whereas the ground for the (R) runs to the frame. Not sure I understand the logic behind that but it something to be aware of.
Hope this helps?
Old May 9, 2020 | 11:33 AM
PNW_IPL's Avatar
PNW_IPL
I would imagine you could tap those two wires anywhere along the branch and run them to your bumper. You can source the ground anywhere there is a good metal contact.
yess! Thank you sir!
Old May 9, 2020 | 11:46 AM
ILM-NC G37S
As it appears you had replied while I was editing my original post..
Keep in mind that for some reason the (L) fog is grounded to the IPDM (pin #41 (blk/wht wire)) whereas the (R) fog is grounded to the car frame. I do not know why nor if it makes a difference, but I did want to point that out.
Old May 9, 2020 | 11:49 AM
PNW_IPL's Avatar
PNW_IPL
I saw that thank you. With this info I should be able to.get them working. Will report back.
Old May 12, 2020 | 08:24 PM
PNW_IPL's Avatar
PNW_IPL
2008 g35 sedan. From the FSM. Pass side wiring for fogs is white/ blackwhite line Driver side is blue/solid black. Still dont know if i need to do anything different with the pass side being grounded to IPDM since im tapping into the two fog wires at the connector.
Old May 17, 2020 | 11:31 AM
PNW_IPL's Avatar
PNW_IPL
well im not sure what the OP issues was but following the wiring diagram I posted above has my fog lights working perfect.
mariio
Mar 11, 2019 12:45 PM
TBau651
Mar 10, 2019 11:31 PM
loganlhadley
May 12, 2017 10:46 AM
Shurik355
Oct 27, 2014 10:59 PM
MaluG37
Jan 6, 2012 09:07 PM
