G37 sedan oem spoiler brake light problem
Old Jan 31, 2017 | 10:11 PM
ericxd's Avatar
ericxd
i have the oem spoiler. Two of the LEDs on the brake light are out. I do not just wanna unplug the brake light. What's the part number for the replacement? Is it worth fixing, in out of warranty. 2012 g37.
Old Feb 1, 2017 | 05:18 PM
LateApex's Avatar
LateApex
Unless I'm missing something... neither the OEM chrome plinth nor the OEM decklid spoiler accessory have any LEDs. The CHMSL is in the back window...
Old Feb 1, 2017 | 06:52 PM
the93owner's Avatar
the93owner
I'm guessing he has the 07-08 trunk spoiler, which does have the integrated brake light. It might be a third party/non-OEM replica, which tend to burn out. OEMs don't usually burn out.
Old Feb 1, 2017 | 10:08 PM
qmantran's Avatar
qmantran
Remove the spoiler. Problem solved. It looks ugly anyways.
Old Feb 1, 2017 | 10:39 PM
LateApex's Avatar
LateApex
Yeah, i thought that too but... if he retrofitted an 07-08 spec spoiler onto a 2012... although it's technically OEM... we can't determine that based on the info he provided.
If it is OEM... he can google "OEM Infiniti parts" and look it up on any number of sites.
Otherwise, with the lack of detail, there's only so much we can do.
Old Feb 16, 2017 | 03:06 PM
ericxd's Avatar
ericxd
yes I have that spoiler and I'm sure 2010+ had them as well (I've seen many with this OEM spoiler). I cant remove it, there is gonna be holes and different shade of paint.
They call all it the light assembly, cost about 400 CAD just for the brake light. That's pretty steep for lights you can only see when you brake.
Old Jun 14, 2017 | 03:16 AM
ericxd's Avatar
ericxd
It's probably a Canadian thing but I see many 2010 and up with these OEM spoiler as well. Anyone know the parts number on the BRAKE LED strip?
https://parts.endrasinfiniti.ca/a/In...D/3846990.html
There is not parts number for the brake LED stripe. How do I fix this without buying a new spoiler?
Old Jun 14, 2017 | 04:19 AM
13_SkylineSedan's Avatar
13_SkylineSedan
Is this it?
https://www.nissaninfinitiparts.com/...Y2LWdhcw%3D%3D
Old Jun 14, 2017 | 11:54 AM
ericxd's Avatar
ericxd
Originally Posted by 13_SkylineSedan
Doubt it. Description says Coupe with spoiler.
Old Jul 21, 2017 | 12:01 AM
ericxd's Avatar
ericxd
anybody?
Old Jul 21, 2017 | 03:44 AM
13_SkylineSedan
How about this:
For Infiniti G35 G37 Sedan 07-12 ABS Trunk Rear Wing Spoiler Unpainted Primer | eBay
Yes, it's a whole wing but for US$100...
The other thing to do is disassemble your wing and try to repair the LED strip yourself. I have no idea how to do that or if it's even possible, but it was assembled somehow so you would think it could be disassembled...
The center brake light (rear deck) on our '06 partially failed because the electrical connections were just mechanically crimped instead of soldered. Ease of assembly I suppose. But that made the lamp susceptible to vibration and corrosion over time and this could be your situation. it is irritating!
Old Jul 21, 2017 | 05:19 PM
slartibartfast's Avatar
slartibartfast
That spoiler (actually a wing) was not available in 2011 in the U.S.
Old Sep 10, 2017 | 10:47 PM
zois's Avatar
zois
I just installed deck lid spoiler for the 2013 sedan, Interestingly enough when I was removing the trim cover for the truck and the back up camera harness for some reason the harness had an empty port that was pigtailed off that. I know that the 3rd brake light is not located on the spoilers for this model but I wonder if its the same harness for the 2008 as mentioned above.
