Infiniti clock light
Old Aug 11, 2016 | 12:37 PM
cruzmisl's Avatar
cruzmisl
The G37 clock uses a SMD led instead of a bulb that you will probably have to solder to replace
Old Aug 11, 2016 | 12:54 PM
x818ray's Avatar
x818ray
2013 SDN. I got the flicker @ 41,000 miles 6mos ago. warranty took care of it.
Old Aug 11, 2016 | 02:54 PM
AUR11's Avatar
AUR11
76k miles on a 2010. Still working fine.
Old Aug 11, 2016 | 03:08 PM
Detail's Avatar
Detail
2009. It flickered at 70k. Went out completely around 80k. And at 90k, the clock stopped functioning.
Old Aug 11, 2016 | 03:48 PM
ctyke's Avatar
ctyke
Seems to happen a lot at ~50k miles I guess... Mine started to flicker somewhere around 50, then took a couple weeks or so to go out permanently. Replaced under CPO warranty.
Old Aug 11, 2016 | 03:59 PM
khan_g37x_'s Avatar
khan_g37x_
I had the same issue with my car replaced under factory warranty at 25k on my 2012 sedan
Old Aug 11, 2016 | 08:55 PM
EricKrz's Avatar
EricKrz
2010 47k miles
Clock light doesn't work at all
Old Aug 11, 2016 | 08:59 PM
Huaniitoo's Avatar
Huaniitoo
I got my light replaced at 33xxx under warranty. It's a common issue
Old Aug 12, 2016 | 11:49 AM
pahanorlando's Avatar
pahanorlando
Interesting to see if the clock was modified to fix the common issue.
It seems that users that had their clock replaced, did not have their next clock fail later on.
Old Aug 12, 2016 | 12:21 PM
rsingerG37's Avatar
rsingerG37
Infiniti has updated the components of the new clocks to address the issue. Hence its new part number.
Old Aug 12, 2016 | 04:46 PM
pahanorlando
would you happen to have new part number?
Old Aug 12, 2016 | 06:20 PM
rsingerG37's Avatar
rsingerG37
25810-1ca1b
Old Aug 12, 2016 | 08:17 PM
Fox331's Avatar
Fox331
2012 with 25000 miles and the clock just went out. It flickered for a while before it went completely out. I'm gonna pull it and see about resoldering/ replacing the leds
Old Aug 12, 2016 | 08:58 PM
  #29
Dembflyr's Avatar
Dembflyr
Sounds like a step by step DIY write up is in order.
Old Aug 12, 2016 | 09:11 PM
  #30
khan_g37x_'s Avatar
khan_g37x_
They replaced the whole clock when I took it into Infinti
