Help H11 FOG CRACKED From Road Rock, Easiest way to remove and change.
Old Dec 14, 2015 | 10:33 PM
marcelo19lp's Avatar
marcelo19lp
Hey guys, I was driving and just realized that I must have had a road rock hit the IPL H11 fog light which caused it to crack and break. What is the easiest way to replace the H11 Fog light housing on the IPL bumper? Do I need to remove the whole bumper?
Thanks!
Old Dec 15, 2015 | 08:49 AM
marcelo19lp
Anyone? That would be great!
Old Dec 15, 2015 | 12:34 PM
m3clubracer's Avatar
m3clubracer
There is a service manual on here, for free.
Old Dec 16, 2015 | 11:18 AM
Randy Johnson's Avatar
Randy Johnson
You should be able to access them from underneath. Remove a few bolts from the fender liner on each side. I have a 10 G37S that I added fogs to. The side with the washer bottle is pretty tight. I have to remove the washer bottle to take out the housing. Beats pulling the bumper off for me.
Old Dec 16, 2015 | 05:59 PM
marcelo19lp
^^ Thanks a lot! It's on my drivers side. I'll start removing some bolts tomorrow. I have an 08 Sports and I added on the IPL bumper.
Old Dec 27, 2015 | 07:41 PM
marcelo19lp
What is a good brand ballast/bulb plug and play for the H11 fog housing for the IPL bumper? I want to match it to the D2S Osram CBI, I have on. Thanks!
Old Dec 27, 2015 | 09:36 PM
slawek65's Avatar
slawek65
I have Osram CBI to and for fog lights I have TRS LED fog lights. Very good match and You don't have to worry about bulbs ballast and all this stuff. TRS led fog lights are direct replacement for Infiniti fog lights.
Old Dec 29, 2015 | 12:24 PM
marcelo19lp
Thanks a lot. I was also looking at LUXEON LED Fog Lamps from Diode Dynamics. I could swear, I read a lot of postings here, of people just plug and play to ballast and that's a wrap. That the fog runs in a different circuit story and its ok to just plug and play. Rather be safe though. The electrician told me that the pigtails from AC Delco gauges cannot carry the current safely and will eventually blow the bulb, fuse, ballast or worse catch on fire.
bikezilla
Feb 25, 2019 04:43 PM
SheLLz
Dec 24, 2015 09:22 PM
Kku808
Dec 14, 2015 01:33 AM
beng37s
Dec 11, 2015 07:11 PM
Alan318
Dec 10, 2015 10:20 AM
