Why did Infiniti do this with the head/fog lights?
Old Jul 24, 2015 | 07:19 PM
  #31
superjoey's Avatar
superjoey
I used these from Amazon.
Amazon.com: JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets H11 H8 LED Bulbs with Projector for DRL or Fog Lights, Xenon White: Automotive Amazon.com: JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets H11 H8 LED Bulbs with Projector for DRL or Fog Lights, Xenon White: Automotive
Here's the before (driver's side) and after (passenger side).
Attached Thumbnails Why did Infiniti do this with the head/fog lights?-img_9097.jpg
Old Jul 27, 2015 | 11:47 AM
  #32
gman69's Avatar
gman69
Originally Posted by superjoey
Awesome... That's the picture I've been looking for.. A before and after picture. Thank you so much. I'm getting those one
Old Jul 27, 2015 | 11:52 AM
  #33
gman69's Avatar
gman69
I know you have a coupe. Do you know if the same bulb will fit 2013 Sedan?
Old Aug 4, 2015 | 05:43 AM
  #34
superjoey's Avatar
superjoey
Sorry about the late reply! I should have subscribed to this thread.
According to the users manual, the sedan takes an H8 bulb and the coupe takes an H11. The bulbs in the Amazon link are both H8 and H11 so it should work! From what I understand, the only difference is the wattage. H8 is 35 watts and H11 is 55 watts. But I guess since these are LEDs, the wattage shouldn't matter.
Post some pics when it's done!
Old Aug 4, 2015 | 05:55 AM
  #35
superjoey's Avatar
superjoey
I did a write up on changing the fog lights. https://www.myg37.com/forums/body-in...n-a-coupe.html
It pertains to a coupe and focuses on getting around the washer fluid tank. From what I've read, the sedans don't have that tank in the way. Anyways, it might help.
Old Aug 4, 2015 | 11:07 AM
  #36
gman69's Avatar
gman69
Sweet thanks....
Old Aug 4, 2015 | 11:08 AM
  #37
gman69's Avatar
gman69
Nice write up..
Old Aug 4, 2015 | 12:16 PM
  #38
superjoey's Avatar
superjoey
Nice write up..
Thanks. (I subscribed)
Old Aug 13, 2015 | 02:22 PM
  #39
TVPostSound's Avatar
TVPostSound
Originally Posted by Selym
Speaking of fog lights, why can't the fog lights be switched on without turning the headlights on? In truly foggy conditions, the headlights are going to reflect off the fog and blind you.
Myles
The "fog" lights work with only the running (parking) lights on.
You don't need the headlights to be on.
Old Aug 13, 2015 | 06:44 PM
  #40
jman09's Avatar
jman09
That's not the case with my 2013 g37x coupe. You can only activate the fog lights when the headlights are on.
Old Aug 13, 2015 | 10:15 PM
  #41
Epiphany's Avatar
Epiphany
I've never seen a car that lets you use the fogs without your low beams on, unless it uses the fog light as a daytime running light. My 12' sedan only works with the headlights in the on position, even though I can't turn my headlights off at all.
GW330
Feb 2, 2024 05:41 PM
superjoey
31
Mar 22, 2023 11:56 PM
Ricio1991
Aug 23, 2015 10:44 AM
Upscale Speed
Aug 6, 2015 04:08 PM
