Painting my grill ??
Old Apr 21, 2015 | 02:22 PM
buggzg37s's Avatar
buggzg37s
Hey guys. So I'm gonna paint my grill black but I want to know what paint slash method is the best. I'm thinking plasti dip and removing the grill to do it. Thanks for your input.
Old Apr 21, 2015 | 04:17 PM
Rybitron's Avatar
Rybitron
I just recently plasti dipped my grill (and fog light surround) I pulled the grill all the way off and it went pretty well. Not sure how long it will last.
I definitely recommend taking the grill off the car to spray plasti dip it.
The car is dirty, but the plasti dip looks really smooth. No imperfections.
Old Apr 21, 2015 | 04:25 PM
blackstorm's Avatar
blackstorm
Thumbs up
I just painted mine 2 weekends ago with matte black plasti dip. Honestly, you can remove the grill if you want it to be perfect, but i thought it would be too much work after i looked up a vid on youtube of some guy taking the grille off. I just shoved my fingers behind the grille to release the front emblem from the grill.. Then I used 3M masking tape and taped off all areas around my grille and headlights and went to town. I followed a plasti dip vid on youtube by some guy named Fonzie doing a VW Jetta. I hit it with a light even coat every 20 minutes in my garage, about 5 or 6 coats in total, then let it dry inside overnight and it came out perfect...
Old Apr 21, 2015 | 04:35 PM
2008G-Man's Avatar
2008G-Man
How hard is it to remove the grill?
Old Apr 21, 2015 | 04:39 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
It's a pain for what it is. The radiator cover is a real hassle. It took me a lot longer to get it off than I am proud to say and I like to think I am pretty mechanically savvy.
Old Apr 21, 2015 | 05:05 PM
Rybitron's Avatar
Rybitron
It is a little bit of a pain, but I was installing my cold air intake at the same time. So I had to either way.
Old Apr 21, 2015 | 07:11 PM
buggzg37s's Avatar
buggzg37s
Thanks for the input so far. Has anyone used any other paint other than plasti dip?
Old Apr 21, 2015 | 07:31 PM
properdropper's Avatar
properdropper
i used regular gloss paint on my grille, i didnt want to put that plasti dip on it.. you can see it a little bit on my pics lol
Old Apr 22, 2015 | 12:17 PM
guy from norcal's Avatar
guy from norcal
I did mine in black with some dupli color. the grill isn't too bad to remove.
Old Apr 22, 2015 | 12:50 PM
Freezy's Avatar
Freezy
All the DIY grille removals i see are terrible i heard taking the grille off is a pain in the ***. Anyone have a link to a clear DIY?
Old Apr 22, 2015 | 03:05 PM
I thought the sedan was simple, coupe may be a bit more troublesome but shouldn't be. Takes me about 10 minutes now since I've done it several times. The two plastic dowel pins on the backside of the radiator cover are the only real tricky parts, they're completely hidden, they're about a 1/4" in diameter and are centered between the 2nd and 3rd back cover bolts facing the plastic coolant tank. You need to get all the bolts/clips undone on that cover then push the cover back as hard as you can to clear those pesky pins, if you don't clear those pins and try to pull it up you'll crack the cover.. Once you do that you can get enough access to get a socket with medium extension into those 5 (It think it's 5) nuts. No need to remove all those wire harnesses off the harness clips.
These DIYs should help
https://www.myg37.com/forums/d-i-y-i...nt-grille.html
DIY: Grille Removal - G35Driver
Old Apr 22, 2015 | 08:57 PM
buggzg37s's Avatar
buggzg37s
Thanks for all the input I ended up going with plasti dip just encase I didn't like it but it came out really good.
Old Apr 22, 2015 | 09:09 PM
properdropper
^^^^ looks really good man! your G def looks a lot better with a black grille like that!! props
Old Apr 23, 2015 | 10:54 AM
NickyP's Avatar
NickyP
Did you sand down the grille first, or paint right over the chrome?
Old Apr 23, 2015 | 06:27 PM
axis.'s Avatar
axis.
Aren't you concerned about plasti dip hitting your radiator?
I want to plasti dip my grill too and saw how much of a hassle it is to remove the radiator cover, which looks like a pain. I'd much rather just spray directly onto the grill but I don't wanna cover my radiator in plasti dip...
Anyone chime in?
