Review: Diode Dynamics XP50 Reverse LEDs
Old Mar 1, 2015 | 04:27 PM
ayarj12's Avatar
ayarj12
Hey guys! I bought Diode Dynamic's XP50 reverse bulbs recently and thought I'd do a review on them after not being able to find one on here. Just a note, I do not have a backup camera. This review is based on about two weeks of use and daily/nightly driving.
I bought them because I have my rear window and two small side windows tinted at 5%. It's basically opaque at night with the windows up. The stock sodium bulbs don't help at all. After some deliberation, I thought that it would be worth the price point. It took a while to justify spending $90 on reverse bulbs, but what convinced me is that they are for safety and they would help a lot.
Tools: Flathead screw driver, 5/16th's screwhead, headlamp flashlight
Install: I used this https://www.myg37.com/forums/d-i-y-i...aillights.html link to remove the tail lights. It's super simple. The hardest part is popping out the taillights while worry about breaking something. Once the taillight is out, twist the bulb housing, pull it out, switch bulbs, twist the housing back in, and you're done. Easy.
Quality: The bulbs are great quality. They're massive and solid. They don't look or feel cheap at all. It feels great in the hand and you can tell its not something cheap.
Review: Diode Dynamics XP50 Reverse LEDs-it5nsfp.jpg
Comparison between stock and XP50
Review: Diode Dynamics XP50 Reverse LEDs-ruiizdl.jpg
Brightness: I'm not sure if it was my unreal expectations for a $90 reverse light, but I was expecting something brighter. This is not to say that these bulbs are not bright. They're definitely high strength LED's, but I was expecting something more. Maybe my expectations were unrealistically high, who knows. They do help at night, though. I've had to roll down my windows considerably less since I started using these.
Before:
After:
Outside Pics:
Review: Diode Dynamics XP50 Reverse LEDs-jdeoe7m.jpg
Review: Diode Dynamics XP50 Reverse LEDs-tcusypi.jpg
Final Thoughts:
I give these bulbs an 8.5/10. They're great quality and look really nice when in reverse. They would be a 10 if they were a tad bit brighter, but again, maybe I just have unreal expectations. Price point is kind of high, but when safety is at stake, its worth it to me. I'm very happy with these! Thanks for reading! Shoutout to Nick C. for answering my questions!
Old Mar 2, 2015 | 01:32 AM
Presto's Avatar
Presto
since they are longer than the stock bulbs, do they still fit in the bulb housing without touching anything?
Old Mar 2, 2015 | 08:34 AM
chilibowl's Avatar
chilibowl
They are not as bright because they are pointing down inside the housing. Since they point down and not outwards towards the rear, they lose a ton of output due to incorrect angle of projection.
You need an L-shaped led that points the projection beam to the rear.
Old Mar 2, 2015 | 07:58 PM
HoldmyMouse's Avatar
HoldmyMouse
I think the very top of the bulb is another LED. Didn't know they are that expensive! They do look very bright though.
Old Mar 3, 2015 | 04:08 AM
araaadi's Avatar
araaadi
wait so the taillights have to be removed for reversed LEDS?
Old Mar 6, 2015 | 12:51 AM
ayarj12's Avatar
ayarj12
They are way longer. I don't think they touch anything, they slipped in easily.
That's interesting! I didn't know that. Can you provide some links about what L-shaped LED's you mean?
Yea the taillights have to be pulled out to gain access to the bulb housing. The removal process is so simple. Its the only DIY that I've felt comfortable doing by myself instead of bothering my mechanic. Three steps. I provided the link in the original post.
Old Mar 6, 2015 | 01:18 PM
smakfactor1's Avatar
smakfactor1
Just a side note, I installed the LED's for my license plate and that alone helped a lot with reversing(especially when looking through the camera).
Old Mar 6, 2015 | 01:59 PM
chilibowl's Avatar
chilibowl
BTW, you should get rid of your extra brake light, it looks fairly silly.
timc00k
Feb 15, 2017 09:15 AM
Landshark
Sep 29, 2015 11:20 PM
Allboutcali
Sep 26, 2015 03:43 PM
