Automatic heaadlights not working right.
Old Dec 15, 2014 | 09:52 AM
forrmark's Avatar
forrmark
When I pull out of my garage with the automatic headlight function on, the dash lights don't always go on. I have to play with the headlight switch to get the dash lights to go on. Sometimes they do go on by themselves after a long delay. What's the problem?
Old Dec 15, 2014 | 10:35 PM
ANMVQ's Avatar
ANMVQ
I have this issue with only my rt headlight ? But the dealer just regot placed it under warrenty. I have the turn the lights off and on again so they both light ? Hope someone knows
Old Dec 27, 2014 | 10:02 PM
Matcbr's Avatar
Matcbr
I have this same problem, right headlight won't turn on in auto setting i have to turn off and on then it comes on. Does anyone know what this problem is and what warranty it would be covered under. 09 G37 55k sedan. Just noticed some slight flickering as well.
Old Dec 29, 2014 | 11:26 AM
MJaga's Avatar
MJaga
If you have aftermarket headlight HID bulbs installed, then it's probably a bulb issue. I tried several lower priced bulbs that simply would not fire on the first try. I ended up biting the bullet and going with Osram, and no issues so far.
If you still have OEM bulbs, then it's most likely a ballast that's going bad.
Old Dec 29, 2014 | 11:54 AM
G37Xtreme's Avatar
G37Xtreme
If you still have OEM bulbs, then it's most likely a blast that's going bad.
I agree. I've tried the newer Morimoto bulbs, and they were hit or miss. I got 2 sets total, and on both sets, there was a bad bulb. One bulb out of each set worked perfectly, and the other didn't. Swapping them left to right, the problem follows the bulb.
My Osram CBI worked flawlessly the first time, and each time since. Buy one, cry once. Get the high end bulbs, if you replace your bulbs.
Old Dec 30, 2014 | 11:28 AM
LOAF3's Avatar
LOAF3
Question on that. If we buy a new infiniti, say q60, are the stock bulbs in the car already of great quality, or would the car have brighter lights going to cbi's.
Old Dec 30, 2014 | 11:32 AM
G37Xtreme's Avatar
G37Xtreme
I'm not sure what's in the Q60 from the factory. I'd guess it's a Philips bulb, which is of great quality and they're bright.
I think the Osrams may be brighter. At the very least, you can change your color temperature to a whiter color with less yellow in it.
Check out this link and read through that thread. It should compare what I believe to be the stock bulbs in your car (philips) to some aftermarket alternatives. I just can't confirm which bulbs you would have in the Q60.
The Ultimate D2S Bulb Test
Old Dec 30, 2014 | 11:33 AM
ANMVQ's Avatar
ANMVQ
we buy different bulb because we want to change the HID color. Light Temp. I Have 8k all around, Same set up as my coupe. The stock bulbs are 4300K, I how ever wouldn't change the Q50's light they are all LED now and match , Wife Car
Attached Thumbnails Automatic heaadlights not working right.-my-g37-8000khids_fogs.jpg
Old Jan 2, 2015 | 02:33 PM
ANMVQ's Avatar
ANMVQ
I was told the bulb is no good, I will be swapping it out tomorrow, I have DD 8k bulbs BTW, Glad I have a few extra's
Old Jan 2, 2015 | 08:43 PM
MrG_NY's Avatar
MrG_NY
I went in for servicing 2 weeks ago and the dealer told me they had a bulliten to check the wiring harness for the right headlight and fog lights shorting. They fixed the harness and replaced the fog bulb. I was having no issues.
Old Jan 3, 2015 | 08:23 PM
ANMVQ's Avatar
ANMVQ
Ok cool sounds like what I might have I changed the bulb and still doesn't come on unless I turn it on and off a few times
j50ny
Jul 21, 2017 10:46 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
New2Infinity
Sep 9, 2015 10:34 AM
ZachThomas
Sep 3, 2015 01:40 PM
