G37 Sedan Illuminated Floor Sills
Old May 6, 2014 | 11:09 PM
  #46
connoisseurr's Avatar
connoisseurr
The tap harness for these is just an extra unnecessary harness - especially if you're tapping a control module like this with 30+ wires on it. It's much easier to tap two wires - takes 5 minutes of your time.
Picture of the BCM and the plug you need to remove, is below. It's outlined in the red box. Remove this plug and remove/pull back the black shield covering the wires. Expose the wires. Locate the sky blue wire and the mint (light) green.
(NOTE: You are looking for the mint "light" green, NOT the thicker dark green wire)
Proceed to tap the following wires:
  • WHITE (SILL HARNESS) connects to > SKY BLUE (BCM HARNESS)
  • RED (SILL HARNESS) connects to > MINT GREEN (BCM HARNESS)
DISREGARD WHERE THE RED WIRE WIRE IS PLUGGED INTO.
TAP THE CONNECTOR HARNESS HIGHLIGHTED IN THE RED BOX AND USE THE WIRES MENTIONED ABOVE.
Old May 7, 2014 | 08:29 AM
  #47
nishfish871's Avatar
nishfish871
Thanks so much...YES that's the harness I was looking at.
Wild question...why is the red wire connecting to the other harness?
Old May 7, 2014 | 08:45 AM
  #48
connoisseurr
I knew someone would ask about this LOL. That is just a 12v source. I will now make a reference in my post above to disregard where the red wire is plugged into.
Old May 7, 2014 | 09:03 AM
  #49
nishfish871
I see it now...big red and bold! You da man for snapping the pic
Now I can put my car back together again LOL!
Old May 7, 2014 | 02:56 PM
  #50
connoisseurr
They sure do look nice. Can't turn them down for $99 + free shipping
Please pardon the terrible iPhone pics. I'll need to snap some photos with my Nikon
Old May 10, 2014 | 01:46 PM
  #51
gsteigerwald's Avatar
gsteigerwald
connoisseur,
thanks for the amazing and detailed DIY write up. It was awesome and very detailed. Couldn't have done it without you. Thank you very much.
I also see what you mean about dremeling out that a piece of the drivers side since its a tight fit for the wire.
Old May 10, 2014 | 03:37 PM
  #52
connoisseurr
It's more of an OCD thing for me. The way I see it, when that wire has it's own slot to fit into, it ensures there won't be any chaffing or pressure crimping the wires.
I'd recommend it to everyone if you have a dremel or a grinder. Doesn't need to be done - you could alternatively put a piece of the provided foam tape down, wrap the shielded wire itself with some foam tape and call it a day. It's not really in a spot where pressure would typically be applied but you never know.
Old May 10, 2014 | 05:24 PM
  #53
Conner, if you have the time (and desire) could you put that great info together in a new DIY thread, I'll even "sticky" it for you.
Old May 10, 2014 | 07:59 PM
  #54
connoisseurr
I'd be glad to do that.
Old May 12, 2014 | 04:10 PM
  #55
connoisseurr
Full DIY posted in the link below. I still need to add a blurb and pictures for how I secured my wires - I will get around to that this week. Hope this can help you all out.
https://www.myg37.com/forums/d-i-y-i...ml#post3777520
Old May 12, 2014 | 09:18 PM
  #56
JohnnyD's Avatar
JohnnyD
Got my sills installed today thanks to Connor! His DIY was a great help. For the guys worried about tapping wires, it's not bad at all. It was my first time doing something like this and it was very easy.
Old Jul 19, 2014 | 10:54 PM
  #57
xxx4reggie's Avatar
xxx4reggie
wow, when will this deal happen again! I've been searching for it but dang its pricey from the dealer
OBG37
Aug 21, 2019 09:23 AM
joeposter
Sep 8, 2015 04:36 PM
ohmyg1990
General Tech Questions
17
Aug 13, 2015 08:18 AM
Upscale Speed
Aug 6, 2015 04:08 PM
