Moisture in Reverse light
Old May 16, 2013 | 07:50 AM
RTom919's Avatar
RTom919
Hi all,
I have moisture IN the reverse tail light (problem A), and also in between the plastics (red/white) of the tail housing (problem B). You can notice the moisture in the reverse (white) light all the time, but the water in between the plastics can only be notice when i open the trunk and the water moves around.
To try and remove the moisture from inside the reverse light (problem A), I removed the reverse bulb and stuck a teabag in their with some rice, let it chill for 2 days. Seemed like it was fine, rained that night, and now is back with a vengeance. Suggestions?
I have no idea how to solve problem B, if anyone can understand what I am trying to say about that. Suggestions on this issue?
*I will try and post pics later when work is over
Thanks for anyone who has thoughts or has had the same issue
*Note: passenger side only (for whatever reason)
User 122320
Jun 12, 2017 01:28 PM
timc00k
Sep 25, 2015 12:35 PM
claudiohv
Sep 17, 2015 01:43 AM
B Feelgood
Sep 13, 2015 05:56 PM
