Infiniti lighted door sills $99
Hey Guys i brought a set of these and i downloaded the install instructions from this thread. But it seems the diy is for a coupe when i have a sedan . Mine didnt come with any instructions can someone help me out?
The install instructions are the same except for the rear sills but the steps I downloaded from here did show how to pop out the rear ones. I bought some cheap plastics trim removal tools from harbor freight 5o make it easier. I am not mechanically inclined and figured it out from this thread.
So does anybody know if it is possible to just get the T-harness seperately from stealership or anywhere else? if it is I will eventually pull the trigger on these because the guy keeps relisting them... infact here...
Infiniti Stainless Steel Illuminated Kick Plates G6950 1NM0A G37 Sedan Full Set | eBay
yeah I know but I don't wanna deal with splicing the wires, just like you I'm electronically incompetent and I decided that I would get them under the circumstances of this great deal but also would be nice if it was all plug and play so hopefully someone here knows if it's possible to get the T-harness seperately
Thanks to contributors on this board, I recently felt comfortable enough to put these kicks on my G. It's really a pretty easy install and no T-harness needed. An alternative to splicing is to use a little contraption called "Add A Circuit" from manf. Littlefuse (others similar available, just the brand I used). The "AAC" basically plugs into your fuse block and enables piggy-back onto an existing circuit. In this case, the circuit/fuse for the door lamps is good candidate and conveniently located in the fuse block down by driver's left foot (for 09 Sedan). I did similar connection about 3 years ago to add a Homelink mirror and have had no problems.
Guys please help me. I just picked up a pair of these and they do not have the t-harness. So i am assuming u have to splice and hard wire. Can you please tell me how do i extend the wires to connect them to the BCM please. I am assuming i have to buy wires and splice the connectors on the the kickplates ... please advise.
New batch of sills on Ebay (thanks to Tony "GShadow37x) for the info!
http://www.ebay.com/itm/INFINITI-Stainless-Steel-Illuminated-Kick-Plates-G6950-1NM0A-G37-Sedan-full-set-/261466924385?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ce0a4a561
http://www.ebay.com/itm/F2310-1NF1A-Infiniti-G37-Sedan-Midnight-Black-Grille-NEW-OEM-/111330132556?pt=Motors_Car_Truck_Parts_Accessories&hash=item19ebcb024c&vxp=mtr
