Infiniti lighted door sills $99
Old Mar 22, 2013 | 10:29 AM
  #76
mystikal's Avatar
mystikal
Nice!!!
Originally Posted by Alaa Wehbeh
Just got mine installed. took about 45 minutes to an hour in total. gotta say they look mad
dont think just buy em people!!
For those that may have thought these were long gone they're still selling on Ebay, that Includes you Rochester (you know you want them).
Just click on the black box
Infiniti Stainless Steel Illuminated Kick Plates G6950 1NM0A G37 Sedan Full Set | eBay
Old Mar 22, 2013 | 01:55 PM
  #77
dagenius01's Avatar
dagenius01
I just googled the part number... it shows up as M door sills. are they interchangeable between M and G?
Old Mar 22, 2013 | 02:17 PM
  #78
mystikal's Avatar
mystikal
Did you read the earlier post? We had trouble installing and had to hard wire into the car (takes like two minutes since I gave the wires needed) its not plug in play bud
Old Mar 22, 2013 | 03:31 PM
  #79
dagenius01's Avatar
dagenius01
Understood.. I guess my concern was more mechanical and also looks.. to see if they were the same.
Old Mar 22, 2013 | 03:52 PM
  #80
I do, you're right. I admit that freely, and I'm jealous. But I'm not going to do it, and it's difficult to explain why.
Begone, Satan Newt!
Old Mar 22, 2013 | 05:03 PM
  #81
sniper27's Avatar
sniper27
Begone, Satan Newt!
I like it too, and I'm jealous also. But I'm not going to do it because:
1. I don't have time
2. Although it's a good deal, it's not really worth the money for me, especially I only see it for 3 seconds when I open my door to get in or out about 3 days a week.
Old Mar 22, 2013 | 05:48 PM
  #82
Hey, Sniper. Well, since you splained yourself, suppose I should too.
I have a set of mod plans that fit an annual budget, it's planned out year over year, and it's (mostly ) prioritized along performance mods. If that were it alone, I could easily fit $100 bit of bling into the mix, but I'm also paying on a car note, so that's part of the overall budget. Keeping to my plans has nothing to do with the wifey, and I certainly make enough to support whatever I want to do with the G. It's just a self-moderation thing, and I'm sticking to it.
Just like you, I teeter back and forth on the value calculation. And it's entirely possible that mid-year I'll do something impulsive if this is a regular supply. If not, I won't be losing any sleep over it.
In the mean time, I'm watching all you guys get your kicks with your kick plates, and I'm happy for you. I'm glad that this is legit, and it's all working out.
Old Mar 22, 2013 | 07:31 PM
  #83
OBG37XS's Avatar
OBG37XS
Hey Mystikal, I read your posts, and see that you hooked up the wires to the BCM. I installed mine today, but saw your install afterwards. I used a add-a-fuse and installed mine to the fuse box to the '10A room lamp' fuse. My kick plates work, but if you have door open and push the switch that thinks the door is closed, my kick plates remain on. I just wanted to confirm that the way you hooked it up (to the BCM), that the kick plates turn off when the door is closed.
Old Mar 24, 2013 | 10:48 AM
  #84
Redpit's Avatar
Redpit
If you install the way Mystikal outlined then the kick plates will shut off when you close the doors.
Old Mar 24, 2013 | 04:02 PM
  #85
OBG37XS's Avatar
OBG37XS
Thank you! Just re-wired today as per Mystikal (but ran white -> sky blue, and red -> red). I removed the courtesy light from the door, and there is a green and red wire going to it. I don't think it matters if you connect the red wire from the kick plates to the red or green, as door switch finishes the circuit. Works just the same and shuts off when door is closed. Thanks again for confirming this
Old Mar 26, 2013 | 08:30 PM
  #86
Edward41890's Avatar
Edward41890
I just installed mine looks awesome.
I just want to give a special thank you to MYSTIKAL
with the help of his diagram and telling which wires to connect
Red to green, white to skyblue
Without him i probably wouldve taken a few hours instead of 1
Old Mar 26, 2013 | 10:02 PM
  #87
Get 'em while they're hot (and cheap) looks like there's 8 sets left
http://www.ebay.com/itm/INFINITI-Stainless-Steel-Illuminated-Kick-Plates-G6950-1NM0A-G37-Sedan-full-set-/251244406748?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3a7f5567dc
Old Mar 26, 2013 | 11:46 PM
  #88
flipmode007's Avatar
flipmode007
I was quoted $250 to install them from infiniti dealership in Ottawa lmao, I will do it myself when ever I get it
Old Mar 27, 2013 | 11:21 AM
  #89
mystikal's Avatar
mystikal
It should be the same, I did notice that the new kick plates are a bit smaller than the oem, non lit ones
Um it should be the same as the wires I pointed out...It should come off once the light is on..maybe you applied it too the wrong wires? Because when I was doing some trouble shootin, trying to figure out which wires I had to use, I came across the same issue and found out the wires I needed too use was the same wires on the courtesy door lights..Light on--> door open, light off-->door closed
Originally Posted by Branden32182
I understand where you are coming from. I have a 2008 G35 and I did it the way he said and the door sills are still staying on.
Thanks!
Your Welcome
No probs...took me a few hours at first looking for that stupid plug...then trying to trouble shoot which wires were which.
Old Mar 27, 2013 | 11:24 AM
  #90
mystikal's Avatar
mystikal
Install it and send me some $$ lol
