Any have experience with 55w HIDs?
Old Dec 6, 2012 | 07:22 PM
Gametrade's Avatar
Gametrade
Thinking about using the high output bulbs to some degree via headlights and/or fogs. Anyone have experience with them as to the point of knowing it won't melt housing or not being able to point head lights down far enough to make them ridiculously right to oncoming traffic.
Old Dec 7, 2012 | 08:11 AM
awais's Avatar
awais
I think you will have to change the ballast that outputs 55w. The ballasts are located inside thr headlight housing.
I have no idea if it will melt the housing.
Old Dec 7, 2012 | 05:34 PM
Saad Ashraf's Avatar
Saad Ashraf
I recently installed 55w HIDs in my fog lights, about 2 weeks ago. Haven't noticed any housing issues as of yet. They're really bright though.
Old Dec 8, 2012 | 04:33 PM
Gametrade's Avatar
Gametrade
Ashraf: where you get them from?
Old Dec 11, 2012 | 04:41 PM
Saad Ashraf
Search Results : VVME.COM, Tattoo Kit, Xenon HID Kit, DVR Surveillance System & Projector
Digital slim ballast 55W, I personally got 6k. For install, ran a relay from the battery vs doing the plug and play method so that both ballasts get equal and uniform power. In addition, theres a nice place to mount the ballasts right behind the bumper so their protected from the elements.. I should have taken pictures.
Old Dec 12, 2012 | 02:13 AM
Saad Ashraf
I changed my foglights to HIDs, not the headlights. I switched the headlight bulbs to the OSRAM 5k to go along with 6k HID fogs. Sorry for the confusion.
Old Dec 12, 2012 | 08:55 AM
pricojorge's Avatar
pricojorge
I tried to run 55w 6k and they looked the exact same as my 30w(?) 5k, and my driver side kept turning off here and there randomly alot.
Old Dec 12, 2012 | 05:30 PM
Saad Ashraf
Did you use a relay to power the ballasts vs the harness where the stock fog lights where plugged into? I think that might have been the reason they kept turning off and on due to the ballasts not getting enough power from the stock harness
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
si_driver
Oct 1, 2015 09:53 AM
BurtoN86
Sep 30, 2015 03:32 AM
halfbreedcuban
Sep 27, 2015 08:58 AM
dlc1988
Sep 2, 2015 09:40 AM
