Help power window problem
Old Dec 2, 2012 | 02:16 PM
B30CBLUE's Avatar
B30CBLUE
09 sedan new to this car. car running only driver window goes up&down. turn car off the other 3 windows work fine. start car and back to only drivers window works. also had battery out of car before driving car maybe problem there. have used search function here and have not seen this problem. thanks for any help
Old Dec 2, 2012 | 02:34 PM
ilovejdm07's Avatar
ilovejdm07
roll the window down then roll it up and hold the button for 10-15 seconds... Repeat on both sides. Problem solved
Resets window swtichs
Old Dec 2, 2012 | 09:38 PM
B30CBLUE's Avatar
B30CBLUE
does the car need to be running. if not what mode- run- acc and is this reset done at each door switch or from the drivers master switch
Old Dec 3, 2012 | 12:43 AM
Rad_Slinger's Avatar
Rad_Slinger
Just do a search. There's literally a dozen posts on how to do the window reset.
If you don't feel like searching, then just read your owners manual....it's in there. You should have read our owners manual anyway.
Please take the time to educate yourself.
Old Dec 3, 2012 | 08:15 AM
2008G-Man's Avatar
2008G-Man
Rtfm .............
Old Dec 6, 2012 | 06:25 PM
B30CBLUE's Avatar
B30CBLUE
ok have a copy of the service manual. printed the page to reset after removing negative terminal wait one minute reattach turn ignition swith ON. windows wont power down but the drivers does. start car than shut off and they all work for about a minute. what am i missing. drivers works anytime runnung or not. thanks for your help
Old Dec 6, 2012 | 08:44 PM
Rad_Slinger
bring the car back to the dealership.....it's defective
Amaadkhan2k
Oct 4, 2024 01:20 PM
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
slawek65
Sep 8, 2015 09:07 AM
ZachThomas
Sep 3, 2015 01:40 PM
