Finally got the fog lights change to HID
Old Aug 29, 2012 | 10:24 AM
glennp_2012's Avatar
glennp_2012
Originally Posted by strictlys
I just ordered a set for myself 3k h8 for my fogs. How easy were them to access? Did you have to take the bumper off?
No you don't have to remove the bumper just remove a few screws from underneath the front cover and a plastic clip inside the wheel well. To remove or pull the light assembly there is a small screw holding it from inside the bumper. Like I said the left side is really easy takes a few a mins. just wanted to make sure that my wires are all tucked away nice and clean. The right side is bit of a challenge specially if you have big hands. You will need a size 8mm close end wrench to remove the assembly. Makes the installation of the bulb a lot easier. Everything is straight forward on the install just follow the connection guide and you should be done within an hour. I wish I took pics while I was doing the install but I didn't even think of it. I would have thought that someone here must have done the install even before I did and posted pics. GL on your install.
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
R1 Dan G37
Aug 27, 2015 09:55 AM
bikerjosh
Aug 19, 2015 11:26 PM
