Help Wiring Up Piranha LED's for Iron Man
Old Apr 8, 2012 | 09:28 PM
SgtGoldy's Avatar
SgtGoldy
Hey guys, I'm looking to preform an IRON MAN look to my light housing using Piranha 5mm LED's. I was wondering if anyone had any insight on how to wire these up. I am experienced with soldering but not really working with LED's. I have no idea what I need or how to wire them up in general. Any information is appreciated.
Old Apr 8, 2012 | 10:29 PM
Rad_Slinger's Avatar
Rad_Slinger
Message breftayka or raulgcustom. I'm sure they can help you out.
Old Apr 8, 2012 | 10:48 PM
SgtGoldy's Avatar
SgtGoldy
Thanks matt, will do
Old Apr 8, 2012 | 10:51 PM
Weiboy718's Avatar
Weiboy718
Hey, did you already ordered those LEDs and is that your only option because i know another one you can buy which is pre wired and SMD surface mounts.
Old Apr 8, 2012 | 10:58 PM
SgtGoldy's Avatar
SgtGoldy
Haven't ordered them I was only considering them because I've heard they are extremely bright and reliable
Old Apr 8, 2012 | 11:40 PM
Weiboy718's Avatar
Weiboy718
Good! I heard they also bright but definitely not as reliable as you heard haha. You should get the ones from Superbrightleds.com, they're called Pre Wired SMD LD1. Same one's Breftaka and many others are using lately! Very easy wiring as long as you have some electrical skills you are golden but if you don't understand something ask the #1 Troll again.
LD1-x series Accent Module Specifications
Old Apr 8, 2012 | 11:44 PM
SgtGoldy's Avatar
SgtGoldy
haha weiboy, always coming through for me. Your my go-to man. So let me ask this, and I'm not sure if you'll know but Ill try anyways. What size is the projector shroud (mm)
Old Apr 8, 2012 | 11:45 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
If you got time, you can stop by and see how I have a set here wired and ready to go. Let me know.
Old Apr 8, 2012 | 11:48 PM
SgtGoldy's Avatar
SgtGoldy
Thanks Raul, when I grab a moment away from work Ill hit you up
Old Apr 8, 2012 | 11:50 PM
Weiboy718's Avatar
Weiboy718
sorry! idk the answer to that haha.
looks like you got better help now, i'm out!
Old Apr 8, 2012 | 11:53 PM
SgtGoldy's Avatar
SgtGoldy
haha thanks weiboy!
Old Oct 15, 2012 | 12:02 AM
roughx021's Avatar
roughx021
How are any of these LEDs mounted behind the shroud? Are they siliconed in the hole or is there a special holder? Also is there room behind the shrouds for all the wiring??
Old Oct 15, 2012 | 01:40 AM
SgtGoldy's Avatar
SgtGoldy
I actually opted not to do them just because I have heard they burn out kind of quick due to the extreme temp put on my the HID's. But I did paint my headlight so I took it apart, and yea there is a lot of room behind the shroud. I would guess it was done using a hole big enough to pass the wires through and then just siliconed. Just a guess, since I did not pursue it.
Old Oct 15, 2012 | 03:47 AM
HeaterKeda's Avatar
HeaterKeda
timc00k
Feb 15, 2017 09:15 AM
Allboutcali
Sep 26, 2015 03:43 PM
dedmanchan
Sep 24, 2015 11:25 PM
SheLLz
Sep 24, 2015 08:02 PM
