HELP! Broke a bulb mount in my headlight
Old Feb 10, 2012 | 09:19 PM
TVPostSound's Avatar
TVPostSound
Originally Posted by RaulGCustom
OP If it's the clip that hold the bulb in place, I have an extra one. I can't enlarge the pic you posted.
https://www.myg37.com/forums/attachm...-back-lamp.jpg
Old Feb 10, 2012 | 10:31 PM
hinomura's Avatar
hinomura
Raul, it is the clip that holds the bulb into place! Thank you so much, you are the man. Please PM me a shipping quote to 30309 and I'll tack a little extra on for your trouble.
Old Feb 11, 2012 | 12:04 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Is it the actual wire piece, or the part the wire clips on to? I'm guessing it's the part the wire clips on to. You'd really have to man handle the wire to damage that.
Old Feb 11, 2012 | 09:44 AM
hinomura's Avatar
hinomura
The part the wire clips on to.
Old Feb 11, 2012 | 10:32 AM
Weiboy718's Avatar
Weiboy718
Fyi! Changing the metal wire clip wouldn't help if it's the projector housing that's been broken.
Old Feb 11, 2012 | 03:12 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
I don't know which part you need bro, this is what I have
Old Feb 11, 2012 | 08:02 PM
Ibanez540r's Avatar
Ibanez540r
That was me in the linked post that did the same thing. I barely touched it and it snapped off. That was several months ago and no issues, but still bothers me to know its broke and possibly loose.
Raul that entire cast piece on the right will do it. If OP doesn't want it, how much?
Old Feb 11, 2012 | 11:17 PM
paleryeder's Avatar
paleryeder
What you need is called the projector bowl, that piece that holds the wire is part of the bowl itself.
Old Feb 13, 2012 | 05:36 PM
hinomura's Avatar
hinomura
After finishing out changing the light bulb I inspected the piece that broke and it will not come off of the projector housing (what paleryeder said), the top screw only allows you to remove the Y-spring. So yes, in fact, I will need to purchase that entire projector bowl off of you Raul. I will PM you about the details. To everyone else who helped thanks for all the advice.
Old Feb 14, 2012 | 12:36 AM
hinomura's Avatar
hinomura
I need the item in red outline. The entire piece.
Old Feb 14, 2012 | 12:45 PM
RaulGCustom
SoCal Driven
ok, sending you a PM
Murkr
Sep 28, 2015 10:45 AM
John B
Sep 27, 2015 11:41 PM
halfbreedcuban
Sep 27, 2015 08:58 AM
