Replacing license plate bulbs?
Old Jan 23, 2012 | 11:16 AM
Dr.Pat's Avatar
Dr.Pat
Has anybody changed their license plate bulbs? How do I access them? Is there a DIY?
I check the DIY section but couldn't find it...could only find DIY for headlights
Old Jan 23, 2012 | 11:20 AM
myk1013's Avatar
myk1013
there are (2) light bulb housing for the rear plates... they simply just clip on/off. (squeeze clips)
Old Jan 23, 2012 | 11:44 PM
Kuro's Avatar
Kuro
https://www.myg37.com/forums/d-i-y-i...ion-guide.html
Old Jan 24, 2012 | 12:00 AM
OB G's Avatar
OB G
Have you even looked under there? I don't want to sound like an a$$hole but the license plate lights are probably the number one easiest mod to do. If you can remove the battery cover from your tv remote control, you can remove the cover to the license plate lights, exposing the bulb. I believe it's a 194 bulb. Should take 5 minutes at most. Good luck
Old Jan 24, 2012 | 01:05 AM
Rad_Slinger's Avatar
Rad_Slinger
The passenger side is a little tricky cause the wire is short. 5 minutes is a little conservative....took me like 7.
Old Jan 24, 2012 | 08:12 AM
Dr.Pat's Avatar
Dr.Pat
no offense taken! In all my previous cars the entire trunk liner needed to be removed to access those bulbs, so I assumed the same was true for the G. After I posted this (before I got any replies) I went out to look and quickly felt foolish for posting this question lol. I tried to come back and delete the thread but couldn't find the delete thread option.
Thanks for the help guys
photocat
Sep 3, 2015 01:46 PM
dlc1988
Sep 2, 2015 09:40 AM
G37X GraSdadow
Sep 2, 2015 04:09 AM
