wiring noob and need a littl help
Old Jan 23, 2012 | 10:27 AM
GET_SOME's Avatar
GET_SOME
hey guys im going to start doing the 2011 non sport fog light conversion to my 2008 G37s now my question is this. how would i wire the bosch plug pigtails if i wanted to eliminate the fog light from the factory position and just run the fogs in the bumper using the factory switch. thanks for any help guys.
Old Jan 23, 2012 | 10:54 AM
Weiboy718's Avatar
Weiboy718
The stock housing has 2 wires that powers the fog. Yellow is + black is -. Theres a few ways you can connect that. You can either cut off the disconnect and pull the wires out through the foglight cover or just simply tap those 2 wires and route it to your pig tail. But be sure to remove the bulb and tape up the disconnect if you're planning on tapping the wires.
Old Jan 23, 2012 | 11:43 AM
VossenG37S's Avatar
VossenG37S
Hey man I can help u just hit me up it's easy u just need to purchase the PT120 pigtails from amazon.com it comes w 2 butt connectors and all u will need to do is connect the yellow and black wires from oem fogs and u will be good !
Old Jan 23, 2012 | 11:50 AM
GET_SOME's Avatar
GET_SOME
@ weiboy thanks for that info
@ vossen will do buddy ill hit you up when i get all the stuff for the conversion
Diode Dynamics
Lighting/Cleaning Products
81
Nov 30, 2021 02:28 PM
flyingnimbus
Oct 3, 2015 12:12 AM
Simm0nS777
Sep 24, 2015 08:19 PM
RexHavoc
Sep 6, 2015 01:03 AM
