Plastidip Removal
Old Sep 19, 2011 | 12:41 PM
qirex's Avatar
qirex
Plastidip Removal
I plastidipped my grille and rear valence however I don't like the look the of the rear valence. Trying to peal this off is next to impossible and I don't want to scratch the paint. Does anyone have tips on taking this off? Goo-gone, warm towel..?
Old Sep 19, 2011 | 12:46 PM
sniper27's Avatar
sniper27
goo gone. it's messy though.
Old Sep 20, 2011 | 03:34 AM
Djfarhan's Avatar
Djfarhan
have fun
Old Sep 20, 2011 | 08:54 AM
Kidcane's Avatar
Kidcane
Florida G Club
Where are all the plasti-dip fan boys chiming in about how great it is and sooo easy to remove?
Old Sep 20, 2011 | 09:11 AM
Blackjack's Avatar
Blackjack
^ Bingo!!!! We have a winner.
Old Sep 20, 2011 | 09:21 AM
soundmike's Avatar
soundmike
Removal is only as easy as how well you put it on. If it's too thin, being rubber, it'll just tear into pieces.
The key to PD is to apply several layers of it. I removed two strips from my grille a while back and that was an easy process -- peel off the corner, score the sections and everything came off in one piece.
Here's a test i did a while back with just one heavy coat. A few more coats and the thing would be completely opaque when held to light.
Peeling back plasti dip - G35Driver
edit: OP, if things are proving too difficult, you could always layer in more of the stuff for the sake of removal.
Old Sep 20, 2011 | 09:27 AM
jjasonSU's Avatar
jjasonSU
Crickets....
Old Sep 20, 2011 | 03:51 PM
jujubii's Avatar
jujubii
its difficult to remove because he probably has too thin of a layer.
its been said, multiple times, that if you want an easy removal process you have to put on more than 1 thin coat.
your best bet will be goo gone, op, just wax your car afterwards.
claybar also works well on the little specs left over.
i have never had an issue removing plastidip. and ive done it many times.
Old Sep 20, 2011 | 06:45 PM
qirex's Avatar
qirex
Definitely sprayed too thin, will try googone for te remnants, thanks for the tips.
Worker perfect on the grille.
Old Sep 20, 2011 | 07:08 PM
jujubii's Avatar
jujubii
btw use regular googone; nothing industrial or super power strength..
37
Oct 17, 2020 11:12 AM
beng37s
Dec 8, 2019 01:21 PM
MrRiv
Sep 29, 2015 04:59 PM
VIVID
Sep 29, 2015 10:58 AM
philttz
Sep 21, 2015 11:12 AM
