Windows moving slow
Old Sep 14, 2011 | 03:25 PM
fastlane45's Avatar
fastlane45
Windows moving slow
Anyone else have this? I'm talking like 7-8 seconds for them to roll up/down I made sure they were clean and even clayed them so its not cuz they're dirty. Can this be fixed under warranty or is it wear and tear?
Old Sep 14, 2011 | 05:13 PM
djguy23's Avatar
djguy23
Have the same problem with my 2010 sedan..but only on the driver side..
Old Sep 14, 2011 | 08:37 PM
cy7878's Avatar
cy7878
may be the window regulator. If so. definitely a warranty item.
Old Sep 14, 2011 | 09:49 PM
BKG37X's Avatar
BKG37X
Get BB grounding kit
Old Sep 14, 2011 | 10:46 PM
buckets's Avatar
buckets
Will a grounding kit really help? I've tried oiling the weather stripping since the window will pull it down sometimes. My driverside window judders goin down sometimes. Oh and they only go slow when I open all 4 at once.
Old Sep 14, 2011 | 10:49 PM
fastlane45's Avatar
fastlane45
I have a grounding kit read my sig.. I can assure you it doesn't help with the windows. Hopefully your right its the regulator and ill get it replaced under warranty. How would you oil the weather stripping?
Old Sep 15, 2011 | 01:04 AM
maxfinity's Avatar
maxfinity
Does anyone have the enbarrassing squeak along with the windows moving up/down slow? I have a 2010 sedan and when my windows get wet they squeak. The squeak is very noticeable. They also seem to be moving slower than normal.
Old Sep 15, 2011 | 01:10 AM
cy7878's Avatar
cy7878
Tinted windows? the tract may need to be lubed. No tint? The tract needs to be lubed. The dealer should do it for free. I had an Accord that did that and the dealer took care of it.
Old Sep 15, 2011 | 01:15 PM
rpm&my_G35's Avatar
rpm&my_G35
I remember this from when I had my 07 sedan.
ITB10-013 2007-2008 INFINITI G35 SEDAN; FRONT DOOR WINDOW MOVES SLOWLY OR SQUEAKS WHEN OPERATED.
Perhaps some of the new ones have the same issue but there is no TSB issued for it...yet.
Old Sep 17, 2011 | 03:39 PM
fastlane45's Avatar
fastlane45
thanks rpm&my_G35 i will definitely bring this up to the dealer when i go for my oil change soon
Old Sep 17, 2011 | 03:53 PM
Rickblkg's Avatar
Rickblkg
Do you have tint? I know when Ive had my other cars tinted it slowed my windows down!
Old Sep 17, 2011 | 04:12 PM
fastlane45's Avatar
fastlane45
No tint I want some tho
Old Sep 17, 2011 | 08:51 PM
rpm&my_G35's Avatar
rpm&my_G35
I've had tint on both my G's and no window problems as a result. That's not to say it's not possible that perhaps some tint films may create a problem.
I don't think Infiniti would issue a TSB for a window problem if it was a result of custom tint.
Old Sep 28, 2011 | 10:10 PM
Lucifuhrman's Avatar
Lucifuhrman
Driver's side window on my Honda Accord acted EXACTLY the same way. I lubed the channels, greased the regulator gear, made sure battery had full charge, etc. It was a bad window motor. Stuck in a new window motor and all worked fine again.
37
Oct 17, 2020 11:12 AM
RexHavoc
Oct 2, 2015 11:47 AM
Jdragon1974
Sep 29, 2015 09:15 PM
MrRiv
Sep 29, 2015 04:59 PM
