IPL/Aerodynamic Bumper Swap Idea.
Old Dec 30, 2011 | 03:28 PM
  #841
OnYourKnees's Avatar
OnYourKnees
I quoted jovercetti because I was referring to the glass amazon fogs he listed. The product page he linked says wiring and switch included. Im curious if the harness was still necessary or the kit included what is needed.
Im aware also of the rock fogs, factory fogs and the acdelco harness.
Old Dec 30, 2011 | 04:07 PM
  #842
TVPostSound's Avatar
TVPostSound
Originally Posted by P Casey
Those are the OEM fogs for the 2011 sport bumper, should be the same as the 2011 non sport OEM fogs.
Brad hooked me up with the 2011 non sport parts, I posted the 6 numbers a few pages back. They should be here next week.
I went ahead and ordered the same fogs as the 2011 IPL, should be here today from Amazon.
This might help others by keeping neat, and using minimal wiring:
On the drivers side under the hood, there is a relay box with open slots.
Good place to drop in the Bosch relay, power can be tapped from an open connector in there, that was meant for the Climate Controlled Seats (Which are only on verts). It has no relay attached!
Spade connector from the 12V beige wire slot to pin 30 of the relay. The relay pin 85 can be grounded right on the fender well, using existing ground point.
Pin 87 feeds the fogs.
Then all you need is either a trigger feed from your existing fogs, or in my case from the running lights to pin 86. I will run a switch to the dash from the trigger feed.
Old Dec 30, 2011 | 05:30 PM
  #843
BooSa37's Avatar
BooSa37
Originally Posted by breftayka
LOL there's a lot of repetitive information throughout this thread.
AMEN to that! Idk how many times I have posted part #'s/websites. Ppl are lazy, just go back a few pages to find out the answer to your questions. (that goes for all of those starting this swap) whatever questions/doubt you can think of somebody has already asked n has also been answered. Not trying to be a **** about it just do a bit of more reading that's all lol
Old Dec 30, 2011 | 06:15 PM
  #844
SmoovE's Avatar
SmoovE
they didnt come with any extra wiring. thats a new description. i had ordered the ac delco wires also
Old Dec 30, 2011 | 06:35 PM
  #845
P Casey's Avatar
P Casey
How is everyone wiring up their fogs??? Running lights or how?
Old Dec 30, 2011 | 06:47 PM
  #846
breftayka's Avatar
breftayka
I spliced mine into the 2008 factory fogs on the headlight and just disconnected the ground from the original fog light.
Old Dec 30, 2011 | 06:53 PM
  #847
Jayson's Avatar
Jayson
How do we wire if we Just want the new Fogs to be on without turn on the original fogs...
don't wanna have both fogs on at the same time..
Old Dec 30, 2011 | 07:26 PM
  #848
SmoovE's Avatar
SmoovE
i tapped into my sidemarker so my fogs come on with my city lights
Old Dec 30, 2011 | 08:27 PM
  #849
TVPostSound
Read my post #842.
The relay is needed. (seriously, do not tap into another system to power fogs)
The switch is optional. Without it the fogs are on with parking lights.
With it, you can turn them off.
Old Dec 30, 2011 | 09:45 PM
  #850
TVPostSound
See my previous post, running lights, relay, with an optional switch.
There is a small unused rubber grommet on the firewall at 5 o'clock to the brake booster, looking from the front, run your wires through there.
switch.jpg?t=1325285373
Old Dec 30, 2011 | 09:55 PM
  #851
SmoovE's Avatar
SmoovE
Read my post #842.
What's the problem with tapping into another system for the fogs? Not trying to mess anything up. I had HIDs hooked up to them.
Old Dec 30, 2011 | 10:07 PM
  #852
BooSa37's Avatar
BooSa37
No problem at all, if done right you should not have any issues. I wire mines with my parking lights, I have hid's no issues at all. Best part all my current bulbs still work like before nothing was affected by me adding the new fogs.
Old Dec 30, 2011 | 10:49 PM
  #853
TVPostSound
Not for now, at least!!!
There's a reason why systems are segregated, and isolated from each other.
To paraphrase you:
"Not trying to be a **** about it just do a bit of more reading that's all lol"
Old Dec 30, 2011 | 11:10 PM
  #854
BooSa37's Avatar
BooSa37
^^lol. I get your point but I didn't start working on cars
Yesterday been doing for a good while now, I ran the same set up on my old maxima for 4 years straight no issues. The way I set mines up I highly Doubt I encounter issues, I can only speak about my set up idk how everyone else is doing theirs. To each their own...enough said!!
Old Dec 30, 2011 | 11:19 PM
  #855
j23a45m's Avatar
j23a45m
i 2nd this, I've done this same mod on my maxims (97,99,& 03) and never had any issues at all.
