reverse light replacement
Old Jan 6, 2011 | 10:05 PM
tjayK's Avatar
tjayK
Hey Guys....sorry if this has already been answered, but i haven't been able to find it anywhere.....
I am in desperate need of some help, im trying to replace my reverse lights with superwhite leds which i purchased, does anyone have an idea of how to get to the lights. I removed all the clamps and everything in the trunk and it seems almost like i have to take out the whole assembly....any help would be really appreciated, thanks guys!
Old Jan 6, 2011 | 11:12 PM
Fezzik's Avatar
Fezzik
In each of the G37 sections The coupe, sedan and convertible, there is a link to the Factory Service manual (FSM). You can download it and see how it comes apart.
You never said what type of g37 you have.
Old Jan 6, 2011 | 11:43 PM
jmlenz's Avatar
jmlenz
Yes you have to remove the entire tail light assembly. There are no access holes like in most honda/acuras.
Old Jan 7, 2011 | 01:14 AM
lzzhang10's Avatar
lzzhang10
Assuming u drive a coupe.
https://www.myg37.com/forums/d-i-y-i...aillights.html
look harder next time lol
Old Jan 7, 2011 | 05:11 PM
tjayK's Avatar
tjayK
hey thanks guys, i drive a g37 coupe....IZZHANG i did find that thread, but i was still under the assumption that there was a seperate way to get into the back up lights....thanks tho guys much appreciated! this job is going to be harder then i thought!
Old Jan 7, 2011 | 05:40 PM
lzzhang10's Avatar
lzzhang10
took me really long the first time.. but the 2nd time took 3 minutes lol.
The trick is use a rubber mallet and repeatedly knock on the end of 2 bolts further towars outside. hammer them in the direction of pulling movement. pull back as you knock and soon the plastic clips will eventually pop out.
good luck
Old Jan 8, 2011 | 09:02 PM
bsowhat1's Avatar
bsowhat1
On the sedan it is easy. Just pull the clips holding the carpet trim to the inner trunk lid. Then you have access to the reverse bulbs.
Old Jan 8, 2011 | 11:27 PM
Fezzik's Avatar
Fezzik
Dont even get me started on taking the lights out on the vert.
Old Jan 8, 2011 | 11:33 PM
christian655321's Avatar
christian655321
if you really want to make a difference on reverse light then just get the LED license plate thing. you dont need reverse light at all if you have that. 16w of LED power blinding bright.
Old Jan 9, 2011 | 08:11 AM
2008G-Man's Avatar
2008G-Man
good luck
Frankly, I would not use this method. Those clips are meant to be pulled off and not pushed. With pushing (hitting with a hammer) you run the risk of the threaded shaft pushing back into the light housing, cracking it and causing an expensive replacement. There are many threads but do the "pull" method, just pull hard, it won't break.
Old Jan 9, 2011 | 08:12 AM
2008G-Man's Avatar
2008G-Man
Really isn't hard .... stupid that it was designed this way but it's pretty easy. You just have to get past the fear of tugging really hard. I would not do it in the dead of winter with cold plastic though .... IMHO
Old Jan 15, 2011 | 01:06 PM
tjayK's Avatar
tjayK
thanks for the info guys, I have the LED license plate lights, and they look amazing.....I am going to wait for the weather to warm up a bit before i start messing with the reverse light install
Old Jan 15, 2011 | 09:35 PM
Fezzik's Avatar
Fezzik
I don't have a problem tuggen on the lights to get them out. The verts trunk is totally different We have support columns for the roof in the way. The way to access the bolts to the lights you have to take the whole trunk apart almost to get to the lights. Again this is for the vert only
superjoey
31
Mar 22, 2023 11:56 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
derekjl
33
Sep 8, 2015 08:40 PM
MJ HINX
Aug 23, 2015 10:30 PM
bikerjosh
Aug 19, 2015 11:26 PM
