Anyone do HID fogs in 2011 coupe?
Old Dec 24, 2010 | 02:38 PM
Dpiz's Avatar
Dpiz
Picked up an HID fog kit for my new 2011 coupe and trying to find how to do it, but haven't come across anything. Has anyone done this before/know how to do it?
Any help would be greatly appreciated.
Thanks!
Old Dec 27, 2010 | 01:02 AM
SPDCRZ's Avatar
SPDCRZ
Thanks!
I just bought a kit as well, I will let you know how it goes when I get it installed. It should be straight forward. I have done them in the past on other cars. Just attach and go pretty much. There should be instructions with the kit as well.
I would suggest doing it from under the car though. you shouldn't need to take off the front bumper. Just take off the skid plate underneath.
Old Dec 28, 2010 | 03:46 PM
maxfinity's Avatar
maxfinity
I have a 2010 sedan with Hid Fogs. I removed the skid plate underneath the car to access the fog light housing. Once removed the drives side was a piece of cake however the passenger side was a P.I.T.A. because the washer fluid reservoir is right behind the passenger fog light giving you little room to access the fog light unless you remove the reservoir.
Old Dec 28, 2010 | 11:23 PM
xxryanlamboxx's Avatar
xxryanlamboxx
I have also just bought the hid kit too and am planning to install it sometime this week. i was wondering the same thing but also cant you install it through the wheel well.
Old Dec 28, 2010 | 11:24 PM
RaulGCustom's Avatar
RaulGCustom
SoCal Driven
its easy, don't worry to much about it.
Old Dec 29, 2010 | 12:39 AM
G-Spot37s's Avatar
G-Spot37s
Danny...I told you I will install them as soon as I'm back in town. Patience is a virtue.
Old Dec 29, 2010 | 12:58 AM
eksigned's Avatar
eksigned
i have 6k hid fogs (h8). the install wasn't too bad...but i took the entire bumper off to just make the entire process less of a hassle for placement of the ballast; mine was plug and play.
Old Dec 30, 2010 | 02:01 AM
maxfinity's Avatar
maxfinity
On the Drivers side yeah but on the passenger side the the washer fluid reservoir is in the way. You would have to remove it.(At least that how it is on the Sedan)
Old Dec 30, 2010 | 08:18 AM
audtatious's Avatar
audtatious
Access can be had through the inner fender liner. Here's an overview of access to the headlight housing from my sedan and the same steps work with the '08+ coupe:
Infiniti G35 and G37 HID bulb Replacement
You should be able to access the fogs on the 2011 going through the fender but would like someone to validate.
Additionally, I suggest using a relay for power as you may have occasional issues with ballasts not turning on if you don't.
superjoey
31
Mar 22, 2023 11:56 PM
maybeg37
Sep 8, 2015 02:33 PM
Ricio1991
Aug 23, 2015 10:44 AM
bikerjosh
Aug 19, 2015 11:26 PM
